‘88-‘91 Belt Tensioner Issues with AC
Old Nov 26, 2024 | 11:58 PM
Siveck's Avatar
Siveck
Default ‘88-‘91 Belt Tensioner Issues with AC
Still trying to understand why my car shakes so badly with the AC on. 1989 L98. When I turn the ac on, the belt tensioner swings wildly. Like 4 inches of travel. Just from the compressor engagement. Could not find an oem tensioner, so I replaced it with a repro, Same issue. All brackets are in place and no obvious cracks in compressor bracket, AC blows cold, just shakes the whole car and swings the tensioner like crazy. Do I need a low mileage original tensioner? Anyone else having the same issue?
Old Nov 27, 2024 | 01:49 AM
ajp01's Avatar
ajp01
Did you delete the frisbee from the water pump pulley by chance?
Old Nov 27, 2024 | 09:11 AM
RWDsmoke's Avatar
RWDsmoke
Had a tuneup lately? Running a little lean at idle can do that.
Old Nov 27, 2024 | 09:43 AM
htrdbmr's Avatar
htrdbmr
Belt may be wrong length (too long) or old and stretched.
Old Nov 27, 2024 | 04:28 PM
Siveck's Avatar
Siveck
I did delete the frisbee almost 20 years ago. I put it back on when this stated happening. Tune up less than 10k miles ago. Belt is correct length with tensioner between marks. I read something about aftermarket tensioners having weak springs? My old GM one from 2008 was swinging several inches with the compressor on and so does my brand new reproduction one. Might need to find a NOS one from GM.
Old Nov 27, 2024 | 04:32 PM
Siveck's Avatar
Siveck
How can I determine if my car is running lean at idle? I have the Auto X Ray scanner for OBD1 but the screen is no longer readable.
To ‘88-‘91 Belt Tensioner Issues with AC
