C4 Instrument panel lights
Old Dec 6, 2024 | 09:15 PM
lorencjackson's Avatar
lorencjackson
3rd Gear
Default C4 Instrument panel lights
Some of the instrument panel bulbs were not working so I bought bulbs and replaced them. Now they don't work at all. Each bulb works outside of the IP. I get a dead short across the bulb contacts even with the bulbs removed, I suspect the little 3 terminal black thing that may be a diode or transistor, it has m(otorola) K 613 1301 on it,
Old Dec 7, 2024 | 11:27 AM
jv9999's Avatar
jv9999
Year?
Old Dec 7, 2024 | 01:12 PM
lorencjackson
3rd Gear
Old Dec 7, 2024 | 02:00 PM
jv9999's Avatar
jv9999
Originally Posted by lorencjackson
1987
This may help you: https://batee.com/pages/84-89-corvet...nd-information
Also: https://www.dropbox.com/scl/fi/9wlwk...=qyzyhqwt&dl=0
Old Dec 7, 2024 | 02:04 PM
jv9999's Avatar
jv9999
1987
Old Dec 15, 2024 | 07:44 PM
lorencjackson
3rd Gear
Update. I found the short; the high beam bulb was shorting across terminals. However, the lights still do not work when the IP is reassembled. They do light when I put 12V across the bulb terminals and several places along the Printed Circuit Board traces on the front board ( the one with the lights and the displays), I cannot get them to light putting 12V to the terminals that connect the rear board. the links to the Batee site do not dive into this detail, but the Batee website does have a quote to repair the power supply to this circuit. which makes me even more sure it is the semiconductor with the "K613 1301 on it,,,any knowledge of this?
To C4 Instrument panel lights
