smog failure
Old Feb 8, 2003 | 01:04 PM
1990white's Avatar
1990white
Default smog failure
I just had my 1990 smog tested and it failed due to high NOx. I get a code 32, any relation. I also have the ckeck engine soon light on at different times.
Any suggestions as to where I start to find the most likely problem?
Martin in Carlsbad, CA :smash:
Old Feb 8, 2003 | 03:26 PM
IBEAM700's Avatar
IBEAM700
From: Looks like I picked the wrong week to stop sniffin glue Orlando
Default Re: smog failure (1990white)
Code 32 is EGR. Might be time for a new EGR valve and switch. :cheers:
Old Feb 8, 2003 | 06:56 PM
1990white's Avatar
1990white
Default Re: smog failure (IBEAM700)
Boo, Boo time. I get a code 23. Is it possible that the cat is blocked? Thanks :hat
[Modified by 1990white, 11:57 PM 2/8/2003]
Old Feb 8, 2003 | 09:03 PM
fixvet's Avatar
fixvet
What is it? 32 or 23?? Still sounds like a code 32 to me. Pretty much the same thing happened to me, before I replaced the EGR valve under the TPI plenum. Easy job to do if you have a service manual. Took me about one hour to do it.
Good Luck,
Old Feb 9, 2003 | 12:38 AM
1990white's Avatar
1990white
Default Re: smog failure (fixvet)
Hi Poway. It's code 23. I just bought the car and it has a few problems. Failed smog with high NOx, check engine soon light comes on and runs hot.
Since you live nearby, where is a safe and reasonable place to take for vette service. I heard the name of Dave Meyer on El cajon Blvd. Any other good places in San Diego or ? thanks, Martin in Carlsbad. :)
[Modified by 1990white, 5:39 AM 2/9/2003]
To smog failure
