Master cylinder options
Old Dec 11, 2024 | 04:29 PM
TylerScott's Avatar
TylerScott
Default Master cylinder options
I'm going to be installing C5 front calipers on my C4 using the Van Steel adapters, and I'm a little concerned about how much larger the piston area is compared to the C4 single-piston calipers. The C5 uses either a 1" or 1.1" master cylinder instead of the C4's 0.88" (7/8") bore. Are there any replacement options out there? Didn't see anything but the stock cylinder on Summit, but I don't know how they're determining compatibility.
I looked into just swapping in a C5 master cylinder, here's what I found: The C5 booster has 4 studs instead of 2 on the firewall side, so it would be difficult to swap the whole assembly. The master cylinder itself doesn't have the same hydraulic connections, and it doesn't have the integrated proportioning valve, but I can work around those differences. The only thing left, as far as I can tell, would be the booster-to-master-cylinder mount stud locations. I measured mine at 3.64" apart, does anybody know if the C5 is the same width? Anybody heard of this being done? I know the C5 brake swap is not uncommon, so there must be some info out there somewhere; have people just decided it isn't necessary to change the master cylinder?
Old Dec 13, 2024 | 12:20 AM
ACMX92's Avatar
ACMX92
2026 Restomod of the Year Finalist
2026 Corvette of the Year Finalist - Modified
2025 C4 of the Year Winner - Modified
2021 C4 of the Year Finalist - Modified
I have C6 Z06 brakes at all 4 corners of my 85. The stock master cylinder is okay but I do plan on installing a 4th gen F-body master cylinder in the future. This thread shows one installed https://www.corvetteforum.com/forums...r-upgrade.html
Old Dec 13, 2024 | 06:10 AM
blackozvet's Avatar
blackozvet
The C4 master will be fine with the C5 caliper.
Just fit the calipers and try it.
Old Dec 13, 2024 | 07:49 AM
TylerScott's Avatar
TylerScott
Thank you so much, this is perfect!!
To Master cylinder options
