Odd O2 readings
Got it together today and the BLM split is unchanged! I plug up the two vacuum accessory lines and the canister purge line too. Still ran bad.
Things I have replaced over a number of months:
I have replaced the O2s twice already so their good. Injectors replaced a little while ago too. Plugs all looked the same and normal (3rd set). On the second opti and plug wires. Replaced MAF, both coolant sensors, IAT, TPS, MAP. Cleaned IAC. New coil and ICM. Resealed intake. AFPR, high volume fuel pump, fuel filter, PCM, cleaned TB.
Using LT1 Edit, I put in a stock program with idle speed, timing bumped at idle, and injector constant changed but this time forced open loop. For the first time in 6 months the car drove super smooth without any bucking! Plus it feels like I have another 20 ft/lbs TQ from idle to 1500 rpm. This smoothness lasted for about 45 minutes and the bucking came back to maybe 5-10% of what it is normally. Been driving it most of the day and the bucking is almost unnoticeable. Bear in mind I have an aluminum flywheel that allows you to really feel the engine. I have always heard that an LT4 Vette with the hotcam can run on the stock program with no drivability issues.
I figure I have fried my O2 wiring to the PCM somehow and that is what is the cause. However, the O2s look like they are active with Autotap. I did not see any burned wires when I was under there but something is wrong. The O2 wiring to the PCM from the connector has 2 blacks and a tan and purple wire. How so I test these?
Maybe you guys have other suggestions to remedy this problem?
