OBD-1 Scanner Options
Old Jan 4, 2025 | 09:45 AM
Steve Swan's Avatar
Steve Swan
1994 LT1 1996 LT4
Originally Posted by IHBD
For 1994 the onboard diagnostics will give you the codes for the Central Control Module, Engine Powertrain Control Module, Acceleration Slip Regulation/Antilock Braking System, and the Supplemental Inflatable Restraint System.
Jumper Terminals 4 and 12 in the diagnostic port. Turn key to RUN. Watch the LCD display. (Looking at the connector, the desired cavities are the fourth from the left in the top and bottom rows.)
The small number is the Module. 1= CCM, 4=PCM, 9=ASR/ABS, A=SIR. The Speedo number is the Code. Cxx= Current, (it exists now), and Hxx=History it set, but may or may not currently exist. Some C codes will only display as H codes because of the nature of the DTC. The "Opti Codes" H16 and H36 will only display as H codes because the engine must be running for them to be "Current". The engine is not running when using the onboard diagnostics.
"- - -" is end of string for that Module. If you want to read them again, turn key OFF, wait about 15 seconds and turn key to RUN. They will start over.
To clear codes: Use the ODO RESET button to select m.7 Where "m" is the module to be reset, and .7 is the clear codes position. For the Engine, 4.7 is selected, then push and hold ENG/MET until "- - -" is displayed. You have to clear the codes in each module.
Learn to access and use the onboard diagnostics. They are quite powerful. They will reveal the Diagnostic Trouble Codes for the 4 systems monitored. And you can clear codes as well. No tools needed, just a 4" section of jumper wire with the ends stripped. This (and much more regarding the capabilities of the onboard diagnostics) is all in Section 8D of the Factory/Field Service Manual as WVZR mentioned.
\ 1 - 2 - 3 - 4 - 5 - 6 - 7- 8 /
\9 -10-11-12-13-14-15-16/
@IHBD Thank you for sharing your time writing me this detailed reply. As has been said many times by other members, the fellowship and support here is invaluable and wonderful. I will begin schooling myself in Section 8D of the Factory Service Manual. I imagine The Manual will define what the different abbreviations are, e.g., CCM, PCM, SIR, etc. I will follow up a bit more after i have studied Section 8D. Other than the VSS not taking care of the "Check Gauges" light coming on at 75 mph, I'm fortunate in that I'm not throwing any codes. Otherwise, I've been methodically addressing minor issues, replacing fluids Other than the VSS, the only issue i have is the ECC doing what seems fairly typical for these older beauties, not shunting the air through its different channels. I've been researching the 'net and stumbled into Batee's wonderfully informative Youtubes, on troubleshooting and repairs for the HVAC Controller, Programmer and Blend Door Motor. I made up a thread under Technical where all these videos are in one post. I never thought i'd become a car guy at the age of damn near 73, but here i am. Thankfully i am in excellent health, and my body will do what my Corvette asks of me, and have 6 decades of mechanical experience restoring ancient, dead motorcycles, so my critical thinking for how i approach things will be helpful getting me moving forward in this new adventure. Again, thank you for your help, it is much appreciated.
Old Jan 4, 2025 | 10:08 AM
Steve Swan's Avatar
Steve Swan
1994 LT1 1996 LT4
Originally Posted by 1985 Vette
For a 94-95 Corvette these are minimum MasterTech 3100 adapters/cables/ etc. needed
Cables:
1) 14/26 Pin DLC Cable (part #'s: TA01150, 02001392, or 02001637). This is the cable used to connect to any vehicle. The ends of these tend to get bent at the end so I reinforce each end with electrical tape.
2) 12V Power Supply Cable (no part#0). MasterTech 3100 has a battery compartment, but there are times you need the 12V option.
Adapters:
1) GM 12/14 Pin ALDL Adapter (part#'s 02001384 or TA01140). Standard GM OBD1 connector.
2) GM 16/12 Pin Non-OBD2 DLC Adapter (part #'s: 03000053, 02001575, or no part#). Special adapter used for 1994-1995 some GM cars (including 94-95 Corvettes) that are OBD1 but use an OBD2 connector). This maybe the hardest adapter to find. I recommend buying a spare.
Cassette:
1) Reprogrammable High Capacity Cartridge (02003137), OR High Capacity Mass Storage Cartridge (02002663). These are the best 2 cartridge choices as they combine the Powertrain, Body Systems (Airbag), and Chassis (ABS) all in one cartridge. Otherwise, you will need separate GM Powertrain, GM Body Systems, and GM Chassis cartridges.
Program Card
1) MasterTech Multi-Function Tester 12 MB Pro-Card MFT Domestic (part # 02003335 or 02003335_02)
Here's the only decent MasterTech 3100 I see on Ebay right now (used and abused ones often have screen issues, so be careful of that). This one has many cables and modules you won't need, but it has the Reprogrammable High Capacity Cartridge.
VETRONIX Bosch Mastertech MFT Pro Series OBD II Scanner + Accessories TESTED! | eBay
You'll need to buy the 94-95 adapter
Vetronix Tech-1 GM 16/12 Pin Non-OBD II DLC Adapter 3000053 Corvette Camaro | eBay
And the GM Program Card:
Vetronix Mastertech 02003335_01 Pro-Card 12 - MFT Pro 6.2 KIA SPS Prog. | eBay
This adds up to $780. Prices have gone up since I bought mine a few years ago, but it is well worth the money if you plan on working on your Corvette.
@1985 Vette Thank you for sharing your time writing this detailed reply about the Mastertech scanner and providing the Ebay links to the scanner, adapter and card. I have purchased these 3 items. Initially, i will be following @IHBD 's suggestion to begin familiarizing myself with Section 8D of the FSB so i can begin learning the nomenclature, increase my understanding of where different components are located in my C4, what their functions are and most importantly address issues as any may come up. So far, having driven the car 1,500 miles since i purchased it September past, issues it came with are minimal and minor, so i think i got a good car even though it has 87,000 miles on it. Reading other member's threads and posts, i have no reason to believe that with attention and care, this car should last me a lifetime. For me, the C4 with the elegant simplicity of its exterior design, wraparound dashboard, how the cabin is laid out, the high frame rails, the comfortable sport seating, not to mention the 180' rotating headlights provides all that i could ever want in an at the least somewhat exotic luxury sports car. I'll check back in after i've received the scanner and parts. The other parts that come with the scanner which are non-specific to the Corvette, i'm certain i will have no use for in the future. I'd like to sell them to recoup a bit of my investment in the scanner. I'd appreciate your suggestions of how/where i can make them available to people who can use them. Again, thank you for your support. As i mentioned to IHBD, becoming a car guy, much less a Vette owner at this stage of my life is being made easier by the wonderful fellowship this forum offers.
Old Jan 4, 2025 | 10:51 AM
IHBD's Avatar
IHBD
Pro Mechanic
Old Jan 4, 2025 | 11:31 AM
Steve Swan's Avatar
Steve Swan
1994 LT1 1996 LT4
Or read the first sentence in the first paragraph of my post again:
the Central Control Module (CCM), Engine Powertrain Control Module (PCM), Acceleration Slip Regulation/Antilock Braking System (ASR/ABS), and the Supplemental Inflatable Restraint (SIR) System.
I didn't put the acronym in parenthesis behind the capitalized definition in the post which is proper use of acronyms. Sorry. But the definitions were there.
@IHBD Yes, thank you so much, no apology necessary, it's on me. i have to admit, getting started learning something new where there's acronyms, abbreviations, with unfamiliar information connected to concepts, processes and procedures i am unfamiliar with initially feels a bit overwhelming to my senses. I have learned the best way for me to learn is reading, videos when available, looking at what's being discussed and then setting up for what needs to be done. in my "other life" i am a therapist, so anything mechanical that i've been exposed to i have self-studied, being mentored and just doing it. So, thanks again! I look forward to learning from you and your participation in the community.
