'86 intermittent TCC/mpg and odd scan data values
What connects the mpg/TCC stuff to the adl link ? I've checked ecm earths at the engine, by disconnecting, cleaning, and reassembly. After all, the car actually works, performs O/K, is tricky to start when cold and has awful fuel consumption (13 mpg) but ...
For a start, consistent connection to the ecm would help !!!
With a 10k resistor (or less) between A and B on the ALDL connector the MPG readout will stop working and 25 byte 160 baud data will be transmitted instead.
On command the ECM can switch to 8192 baud instead. MPG will still not work.
ENGINE USAGE:
5.0L PFI CPC - (LB9) - (F) - 87,88 (160 & 8192 baud)
5.0L PFI CPC - (LB9) - (F) - 86 (160 baud only)
5.7L PFI CPC - (L98) - (8) - 87,88 (160 & 8192 baud)
5.7L PFI CPC - (L98) - (8) - 85,86 (160 baud only)
DATA PIN : READ DATA ON PIN "E" OF ALDL CONNECTOR
BAUD RATE : 8192
MODES : DATA STREAM ATTACHED FOR ALDL MODE 1
THESE ENGINES USE A 'HYBRID' ECM, AND THE 8192 DATA
COMMUNICATIONS OCCUR ON ALDL PIN 'E'
Serial data shall be unidirectional from the ECM to a connected
device at 160 baud when the ECM is not in the ALDL mode. When the
ECM is in the ALDL mode (10k), the ECM shall transmit the normal
25 parameter ALDL list at the 160 baud rate. The ECM shall then
be moded to listen for a period of 50 ms for an inbound message
from an ALDL test device at an 8192 baud rate. If a valid message
is received, communications shall continue at an 8192 baud rate
until a power down reset. Otherwise, the ECM shall be moded for
160 baud, transmit the 25 parameter ALDL list and then listen for
50 ms for an 8192 baud inbound message.
Maybe I need a new ECM and PROM. Where from (in the UK ?)
