Help with digital 6
Old Feb 9, 2003 | 03:31 PM
ZRWANABE's Avatar
ZRWANABE
Cruise-In III Veteran
Default Help with digital 6
I installed my digital 6 to get my car ready for the nitrous kit and I hate it.
My tach doesnt work and my service ASR light comes on so I unplugged it. I used the MSD plug in kit to install it so i dont think it is installed wrong, plus the car feels weird at an idle and breaks up at the top of the gears.
What should I do I am going to need it when I get my Nitrous kit next week for the timing retard. Ive tried everything and i dont know what to do.
If anyone has had these problems let me know what you did to fix them
thanks
speedy
Old Feb 9, 2003 | 03:37 PM
Bruce's Avatar
Bruce
Default Re: Help with digital 6 (ZRWANABE)
Yup, s few yrs ago that was exactly happened to me on my 1993LT1 vette. With this forum helped, I solved the problem. You need to by pass the tach fiter. it in front of your water pump, a small black box 3/4 x 1".
ps. this is for LT1 car. not sure L98 though
Bruce
93LT1 Conv w/ZF6
Blown D1-SC/N2O
ARE built 383ci/Stage II heads
Old Feb 9, 2003 | 03:41 PM
ZRWANABE's Avatar
ZRWANABE
Default Re: Help with digital 6 (Bruce)
Ok well ill try it do you think this will solve my ASR problem too?
BTW I have a LT1
Old Feb 9, 2003 | 03:43 PM
Bruce's Avatar
Bruce
yup. Your ASR light will be off and your tach will work as normal
Bruce
Old Feb 10, 2003 | 07:38 PM
red-y's Avatar
red-y
Good luck - I just got rid of mine. :steering:
Old Feb 12, 2003 | 03:08 PM
92LT1Roadster's Avatar
92LT1Roadster
Default Re: Help with digital 6 (red-y)
I had the same issue. Insure you bypass the tach filter. ALSO INSURE YOU DISONNECT THE BATTERY FOR 20 MINs. Let the computer reset, then it will work with the digital 6 plus
[Modified by 92LT1Roadster, 10:39 PM 2/20/2003]
To Help with digital 6
