Problems with MSD DIGITAL 6
Old Feb 9, 2003 | 03:31 PM
ZRWANABE's Avatar
ZRWANABE
Cruise-In III Veteran
Default Problems with MSD DIGITAL 6
I installed my digital 6 to get my car ready for the nitrous kit and I hate it.
My tach doesnt work and my service ASR light comes on so I unplugged it. I used the MSD plug in kit to install it so i dont think it is installed wrong, plus the car feels weird at an idle and breaks up at the top of the gears.
What should I do I am going to need it when I get my Nitrous kit next week for the timing retard. Ive tried everything and i dont know what to do.
If anyone has had these problems let me know what you did to fix them
thanks
speedy
Old Feb 9, 2003 | 03:41 PM
95AquaC4's Avatar
95AquaC4
Default Re: Problems with MSD DIGITAL 6 (ZRWANABE)
This may sound obvious, but check all your settings. Be sure they are all correct. Also, if you have altered your stock rev limiter with a chip or computer re-burn, put the digital box at the same or about 200 rpm higher. Not sure if this is the problem, just throwing it out there.
[Modified by 95AquaC4, 3:44 PM 2/9/2003]
Old Feb 9, 2003 | 03:46 PM
scorp508's Avatar
scorp508
Did you try bypassing the tach filter? This is a common thing.
Old Feb 9, 2003 | 03:47 PM
ZRWANABE's Avatar
ZRWANABE
Default Re: Problems with MSD DIGITAL 6 (95AquaC4)
Yea i checked that High side is set at 6500 and i had to set the timing retard and two step at 0 to get the car to not break up at the top of the gears
To Problems with MSD DIGITAL 6
