So recently I replaced my headlight module and also replaced the driver side headlight motor and I notice after that the headlights started moving but after a few turns my passenger motor went out and stop moving then it just completely went dead so I assumed it was the motor and I decided to replace it today. after some work I put everything back together but still the headlight will not turn but my driver side does and my light shows as well I’m really unsure what happen maybe it could be with the wiring?
Can you manually move the headlight by turning the **** on the motor. If you cant something jammed mechanically. If you can then id check for power at that headlights connection
