88 corvette dies when it gets to operating temp
Old Jan 29, 2025 | 08:43 PM
Brody.123's Avatar
Brody.123
2nd Gear
Default 88 corvette dies when it gets to operating temp
88 Corvette dies after getting to temp but you can give it gas and it won’t die. And throws codes 44, 52, 53, 54, and 55
Old Jan 29, 2025 | 09:34 PM
tequilaboy's Avatar
tequilaboy
Err 44 o2 sensor lean
err 52 cal pac missing
err 53 over voltage
err 54 fuel pump voltage
err 55 not used
Old Jan 30, 2025 | 03:58 PM
Tunedport90's Avatar
Tunedport90
Sounds like it has a bad 1227165 ecm
Old Jan 30, 2025 | 07:18 PM
Brody.123's Avatar
Brody.123
2nd Gear
I replaced the prom chip but that didn’t fix it, do you know how I could tell if the ecm was bad?
Old Jan 30, 2025 | 07:24 PM
Tunedport90
The 165 seems to have bad solder joints when old. Can wrap on the ecm case with a screw driver handle while it’s running. See if it dies or runs rough. The bogus code 55 is concerning.
Old Jan 30, 2025 | 07:25 PM
Tunedport90
it’s odd the memcal going bad. Unless it’s an old Hypertech. Some had issues.
To 88 corvette dies when it gets to operating temp
