Coolant flush
Old Jan 30, 2025 | 09:55 PM
LixC4's Avatar
LixC4
Default Coolant flush
I have a 1991 Coupe L98.
So I read on the forms how to do a flush.
this is what I did
0. TURN ON HEAT and raise temp to max (this is so it's not forgotten).
1. drain radiator (pet-**** on passenger side).
2. close pet-****.
3. Fill the overflow tank with distilled water.
4. SLOWLY fill the pressure tank with distilled water to 1/2 inch below the bottom lip.
5. start car, within 1-2 minutes, add additional distilled water, keeping level 1/2 inch below the bottom lip, then cap off.
6. bring idle speed to 2k rpms for 5 minutes, watching both temp gauges (analog and digital on dash). Both should climb somewhat evenly -- do not allow to overheat, but you want the temp to get to around 200 for at least 5 minutes.
7. turn off engine.
8. allow to cool for about 15 minutes.
9. open radiator pet-**** (do not touch radiator cap).
10. drain radiator -- remember system will have some pressure and will be hot). After 1-2 minutes, open radiator cap (pressure should be relieved so no spewing or leakage).
11. repeat steps 5-11 at least 4 times, but continue until water drained out of radiator is nice and clear (or your down to just 2 gallons of distilled water).
I did this till water came out clear^
My question/ issue is When I went to do my fainal adding the coolant and water at 50/50 mix. It will only take 1 gal of coolant and 1 gal of water. I cannot add anymore. I thought the system held a lot more than that. Any thoughts or ideas? I let it ideal with the cap off to let bubbles come out but that didn't do much. the system is defiantly holding pressure. Not sure what to do or if something is wrong.
Old Jan 31, 2025 | 02:08 PM
ramahon's Avatar
ramahon
Draining from the rad is at best 50% of your fluid (which would explain the 2 gal refill vs. near 4 gal total capacity). Engine block /heater core holds the remainder, which would drain through your knock sensor on the undercarriage. With that said and based on steps taken, you've reasonably flushed** your old coolant by the process of continuous dilution and the process you followed is certainly more effective than those that just drain the rad once, clean and refill. You've at least cycled clean water through the entire system multiple times and dumped it. During the refill it sounds like you've burped the system as well, so you should be good to go. Good time to check your rad cap for proper function too!
Side note - given you flushed with distilled water I think it is reasonable to assume that the engine block was near 100% water. If you refilled the remaining 2 gallons at a 50/50 ratio, your total system is closer to 75% water / 25% coolant...which is more ideal for the Texas summers you endure.
Old Jan 31, 2025 | 02:18 PM
LixC4's Avatar
LixC4
Thanks for the reply! Yeah what I most was worried about was the mixture being off and there being too much water in there. Thank you for going over this with me I feel a lot better. Where I am at it can get up to 114 degrees in the summer. The AC in the Vett doesn’t work so I doubt I’ll be riding around when it’s that hot. I took her for a test drive today. She stayed nice and cool.
Thank you!
Old Feb 1, 2025 | 07:14 AM
Whaleman's Avatar
Whaleman
Shop vac flush works! - CorvetteForum - Chevrolet Corvette Forum Discussion
Your cooling system is different than my 96 LT1 but I bet you could figure out how to use this method to flush out your block. Dan
To Coolant flush
