4+3 trans problem
Old Feb 1, 2025 | 04:27 PM
Richs85's Avatar
Richs85
2nd Gear
Default 4+3 trans problem
overdrive not operating properly, took it to a transmission shop, and they said they could get a rebuild kit. Replaced clutch plate, throw out bearing, and installed kit. Operated fairly well before putting it away for winter. Spring came, only had put about 100 miles on car. Trans fluid had big leak. Took it back, they said some of the switches in the unit were bad, and they could not find replacements, so they disconnected all the switches and said it would operate just like a normal 4 speed (no overdrive). It seems ok, but is that actually an ok fix?
Old Feb 1, 2025 | 08:03 PM
s carter's Avatar
s carter
Find out what switches make them elaborate because yes some things are possibly discontinued but it doesn't mean they don't exist on shelves junk boxes and take out transmission
Old Feb 1, 2025 | 08:25 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
it can be fixed. what switch ? pressure switch?
Old Feb 3, 2025 | 01:04 AM
jazfe's Avatar
jazfe
What year?
Trans switches changed a lot over the years. My 86 only has one switch where as the earlier models had as many as three.
Old Feb 3, 2025 | 07:28 PM
solar88's Avatar
solar88
Just to be clear, did the trans shop rebuild the OD unit and install a new clutch on the manual transmission ? You say it operated fairly well, does that mean the manual transmission and OD unit functioned correctly up until you parked it for the winter ? When you say the trans had a big leak, are you talking about the OD unit ? If so, were the leaks coming from the “switches” ? If so, then disconnecting the switches won’t fix the leak, unless they removed them and plugged them.
If they plugged the leaks and topped off the fluid in the OD unit, then it should be okay to drive. It would suck if the OD unit was stuck in overdrive though, but I’m pretty sure without input from the OD switch it will stay out of overdrive.
Old Feb 3, 2025 | 07:43 PM
conniekalitta's Avatar
conniekalitta
You have to be very careful with the polarity of the transmission switches if this is an 84/85 4+3 with the set of three. One of the switches closes in gear while the other does not. If their testing of the switches did not take this into account, then perhaps they thought the switches were duds.
I suppose disabling the overdrive "fixes" the issue of a malfunctioning unit, in the same way that turning off a light switch will make a poorly painted room look great. If their rebuild was correct and the unit is just experiencing some electrical troubles, I guarantee you there is enough experience on this forum to get that 4+3 working properly again.
To 4+3 trans problem
