Broken Intake Bolt
Old Feb 2, 2025 | 12:52 PM
LixC4's Avatar
LixC4
Default Broken Intake Bolt
Just found this nice little surprise from the previous owner.
Question #1 can someone tell me what size and threads this bolt is so I can buy a replacement.
Question# 2 how serious is it to leave it like this for a little while? I have not noticed any symptoms.
Question #3 any advice on how to get the bugger out? Looks like I got enough threads hanging out to maybe get vice grips on it.
Old Feb 2, 2025 | 05:27 PM
Whaleman's Avatar
Whaleman
If you are going to try the vise grips I would start soaking it down with your favorite break free chemical. Dan
Old Feb 2, 2025 | 06:26 PM
Aardwolf's Avatar
Aardwolf
With the runner removed a lot of bolt would be there to use. An intake leak would show some symptoms like air squealing noise, fluxating idle, etc.
Old Feb 2, 2025 | 06:46 PM
ajp01's Avatar
ajp01
Yep. Exactly.
Old Feb 2, 2025 | 08:06 PM
LixC4's Avatar
LixC4
well she purrs at idle. No smoke no fluctuating.
I am confused what you are saying about taking the runners off for more bolts?
Old Feb 2, 2025 | 09:00 PM
IHBD's Avatar
IHBD
Pro Mechanic
The broken bolt is sticking out of the runner flange about 1/8". If you remove the runners, the bolt will be sticking out of the manifold an additional 1/2", the thickness of the runner flange.
In any case, the bolt is seized in the manifold, that's why the head got broken off. With the runner removed, applying heat and penetrating oil to the bolt would be more effective in facilitating its removal. Also, with the runner removed, there will be more room to get the vice-grips or a stud remover on the bolt stub.
Old Feb 2, 2025 | 09:55 PM
LixC4's Avatar
LixC4
got it! Thanks
Old Feb 2, 2025 | 10:59 PM
dburgjohn's Avatar
dburgjohn
There are also extractor sockets out there. Unlike vice grips which can slip and loosen, the harder you turn the more they bite in.
Old Feb 2, 2025 | 11:31 PM
WVZR-1's Avatar
WVZR-1
Size is M8-1.25 x various lengths dependent upon exact location. Purchase after removal.
To Broken Intake Bolt
