1988 corvette resurrection
Old Feb 3, 2025 | 05:43 PM
dwilli57's Avatar
dwilli57
2nd Gear
Default 1988 corvette resurrection
Looking at trying to save a 88 base with engine and transmission from a doner 1990, i have the wiring harness in the 88 and the complete 90 with engine , trans, rear diff but a junk title, has anyone done a transplant like this, i know the 90 doesn't have a cold start injector or MAF sensor could the 90 harness be used under hood?
Old Feb 3, 2025 | 07:12 PM
solar88's Avatar
solar88
I believe your issue using a 90s engine in a 88 will be more of a ECM issue. I could be wrong. My idea would be to transfer the intake and sensors from the 88 engine onto the 90s engine and use the cold start injection set up
Old Feb 4, 2025 | 01:02 PM
dwilli57's Avatar
dwilli57
2nd Gear
kinda my thinking ...except no engine from the 88, any oyher thoughts?
Old Feb 4, 2025 | 06:08 PM
solar88's Avatar
solar88
Use the 90s donor engine and get a 87/88 TPI intake with the cold start injector, pretty sure the rest of the 90s TPI plenum will bolt right up to it.
To 1988 corvette resurrection
