Lt1 carb conversion progress
Old Feb 25, 2025 | 03:21 PM
Vetteman1939's Avatar
Vetteman1939
Originally Posted by marshallnoise
On my L98, I used a Carter Crossfire Injection fuel pump that puts out 12 psi. A regular regulator will knock that down to wherever you want it. The fuel pump was a measly $30 off fleaBay brand new.
I had similar reasons to convert to carb on my car as the OP did: Crappy condition of the wiring mainly.
thats a good idea !!!!
Old Feb 27, 2025 | 07:59 AM
wilcar's Avatar
wilcar
Default Fuel pressure regulator
I use a Mallory 4309 fuel pressure regulator on my carbed 84 C4.
Old Feb 27, 2025 | 09:26 AM
Vetteman1939
I swapped up and ended up buying a carter fuel pump for a 83 vette, only pushs 12 psi, and bought a regulator with a return line to get it down to 7psi
Old Feb 27, 2025 | 10:29 AM
pltmgr's Avatar
pltmgr
I fully understand your concern with "outdated" electronics and not to rain on your parade but Im always fighting with my carburetor vehicles due to todays gas. If you drive the vehicle frequently you'll have less issues, if not....
If you do have start to have carb problems look on the C2/C3 forums where there numerous threads regarding carb issues.
Old Feb 27, 2025 | 10:34 AM
Vetteman1939
yep gas today sucks, but carbs are easy, and there is a store next to me that sells non ethanol gas still so thaf helps a little . But appreciate the info
Old Feb 27, 2025 | 05:01 PM
marshallnoise's Avatar
marshallnoise
I am switching over to an Edlebrock for this very reason. I guess they tolerate sitting a lot better than the Holleys. No idea why.
Old Mar 7, 2025 | 08:42 AM
Vetteman1939
Fired it up today but can't figure out how to post video says not correct file type
Old Mar 7, 2025 | 08:47 AM
Vetteman1939
Here is a YouTube link of my carb conversion first run
Old Mar 7, 2025 | 09:16 AM
rremesal's Avatar
rremesal
That sounded really smooth to me.
I've owned only one car with a carb...1981 Oldsmobile Cutlass LS 4-door. That car was so smooth, at times you could not tell whether it was running or shut off.
I don't think anyone can deny the advantages of fuel injection, which is superior in almost every way. The simplicity of a carb though...it can't be beat.
Old Mar 7, 2025 | 09:27 AM
Phobos84's Avatar
Phobos84
I think as to simplicity it depends on your experience. I tried carb swapping my 84 years ago. I couldn't make it run. It would start and die. I never figured it out. I was beyond frustrated. I'm a computer nerd so for me it's so easy to just plug a laptop into the car and it tells me what's wrong. That same car is LS swapped now with a Holley ECU. I can tell my exact AFR and set spark advance however I want. I don't have a clue how to tune a carb or a mechanical distributor. So for me fuel injection is much simpler. I also can't data log a carb. To be honest I have no idea how guys did it for so long before fuel injection. Hell I can't even see how rich my engine is running by looking at spark plugs being I run E85.
Old Mar 7, 2025 | 09:49 AM
Vetteman1939
You are definitely correct, some cant tune a carb on a lawnmower but are a Wizz on fuel injection and vise versa. Ive been blessed to have experience on both for the last 25 years. Both fuel injection and carbs have there spot. However i may be doing the holley sniper 2 in the near future lol
Old Mar 7, 2025 | 10:12 AM
rremesal's Avatar
rremesal
No doubt your statement is valid. On the other hand, electronics can really mess with a person's head to the point of getting rid of the car out of frustration. I read a post not long ago where a certain Corvette had non-stop knock retard. From what I read; GM engineers were involved and had their hands on this car full time, as I believe the car was lemon-lawed and sent back to GM for this issue. The engineers could not figure out what was the deal with the car. They reached out to Delco-Remy and their engineer stated that "the wire connectors at the knock sensors had some sort of plating on them and were designed to be removed and re-installed 4-5 max. After that, the plating would be gone, and the knock sensor(s) would go haywire". After the GM engineers changed the KS harness, all was good.
I think it's safe to say that even the most advanced tuners would have a hell of a time diagnosing that.
Performance-wise, the biggest drawback I've seen on carbs (from Westech videos) is fuel distribution, where one cylinder may be fat and another lean. This is mostly due to manifold design, air speed and fuel coming out of suspension. Then again, I've seen posts where the TPIS minirams have something similar on the 2 front cylinders.
Old Mar 7, 2025 | 10:16 AM
  #33
Phobos84's Avatar
Phobos84
It's funny you should say that about the lawnmower. This summer I might be fuel injecting my zero turn. 🤣
I'm so sick of dealing with carburators I'm trying to remove them from my life. I already have a nice electric chainsaw, weed eater, and poll saw. Next is to trade in the four wheeler on something fuel injected and then a simple fuel injection kit for the mower. My hatred of carbs runs deep.
Old Mar 7, 2025 | 10:24 AM
  #34
Vetteman1939
lmao
