I need some ENGINE PICS pass side L98.... HELP
Old Feb 10, 2003 | 02:40 PM
StealDads67's Avatar
StealDads67
Default I need some ENGINE PICS pass side L98.... HELP
Hey Guys.. I need some pictures of the passenger side of the engine compartment..... I need to see the differences between the earlier L98 A/C and newer style 90-91 A/C units.... Any info would be great.....
Could they be switched if needed... Say me going to a earlier A/C setup... The newer ones were bigger and tok up more rom and hinders the ability for me to mount the turbo on that side....
Thanks Guys
Old Feb 10, 2003 | 05:41 PM
bill mcdonald's Avatar
bill mcdonald
Default Re: I need some ENGINE PICS pass side L98.... HELP (StealDads67)
Old Feb 10, 2003 | 05:42 PM
bill mcdonald
Default Re: I need some ENGINE PICS pass side L98.... HELP (bill mcdonald)
this 89 has the same compressor, but you will notice the radiator fill is not there.
Old Feb 10, 2003 | 05:53 PM
vetracer's Avatar
vetracer
I have researched doing just the opposite of what you are trying to do. I want to change out my compressor on my '86 (I think it is called an R4 compressor) to the Nippondenso. I beleive this change took place in '88.
The older compressors are subject to moan and vibration problems. That's why I want the newer style. If you don't use A/C that much, this shouldn't be much of a problem. In Arizona, you use it a lot.
What I have found it would take to change compressors is a pretty substantial list. You need all of the accessory drive brackets for the passenger side of the motor as they are different. You will also need all of the hoses and plumbing, dryer, ect. I have pulled most of the brackets from a wrecked car but won't make the change until I rebuild the motor in a year or so.
I'll take some close up pics tonight and post them in the morning. :seeya
[Modified by vetracer, 10:54 PM 2/10/2003]
Old Feb 10, 2003 | 05:58 PM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
don't know about switching them.... here's my '85 and my '90 for comparison:
1990
1985
[Modified by Marcho Polo, 5:05 PM 2/10/2003]
Old Feb 10, 2003 | 06:14 PM
StealDads67
Default Re: I need some ENGINE PICS pass side L98.... HELP (Marcho Polo)
Hey Guys thanks for all you help with the pictures...... Gonna have to think of a way around this
Old Feb 10, 2003 | 06:32 PM
bill mcdonald
Default Re: I need some ENGINE PICS pass side L98.... HELP (vetracer)
He's not the only one thinking of doing this.
What exactly is needed? I already figured the bracket, the compressor, the lines, and a new belt.
Why does the dryer have to be swapped?
Does this go beyond the dryer?
Old Feb 10, 2003 | 07:47 PM
CorvetteZ51Racer's Avatar
CorvetteZ51Racer
It's easy! You live in NY! Pull the A/C! How hard was that? ;)
Old Feb 10, 2003 | 07:55 PM
StealDads67
Default Re: I need some ENGINE PICS pass side L98.... HELP (CorvetteZ51Racer)
Yea I could probably get away with ripping it out... but so can anyone else.... Its not cool when you just rip stuff out... You know you did a great job when everything still works you know what I mean...... Ill have to start doing some creative thinking..... :yesnod:
Old Feb 10, 2003 | 08:08 PM
bogus's Avatar
bogus
You do know that all this is gonna all but require you to change over to R134 refrigerant.
if you are out to emulate the Calloway turbo install, the turbos bolted directly to the exhaust manifold.
Old Feb 24, 2003 | 03:18 PM
TreyZ28's Avatar
TreyZ28
blown 383 is creative :)
To I need some ENGINE PICS pass side L98.... HELP
