Power steering pump design
Old Feb 23, 2025 | 03:12 PM
93YellowVette's Avatar
93YellowVette
Cruising
Default Power steering pump design
Hello all! I'm removing the power steering pump on my 93 C4. The manual indicates there are three bolts. And I have removed three bolts on mine. However, when I look up pumps specifically for my year online, the pictures show a design for 2 long bolts and 1 short bolt. Mine has 2 short bolts and only 1 long bolt by design. Not sure how I'm going to find the right design when I need one.
Old Feb 24, 2025 | 03:40 PM
Whaleman's Avatar
Whaleman
If you can't find the right one turn one can rebuild yours. Dan
Old Feb 24, 2025 | 04:57 PM
93YellowVette
Cruising
Default Thanks
Thank you Whaleman! As it turns out, I was incorrect. There actually ARE two long bolts. One was hidden. And I was thrown off because one of the two short bolts isn't attached to the pump. It holds a support bracket for the pump.
To Power steering pump design
