Replace leaking fuel lines
Old Mar 17, 2025 | 08:32 AM
Techun's Avatar
Techun
Default Replace leaking fuel lines
Well, after a period of smelling some gas, it escalated and now there's a puddle of gas by the passenger rear tire. I removed the little splash shield to see the charcoal canister area and the fuel lines up there are extremely corroded, 99% sure they are the source of the leak, and either way definitely need to be replaced.
I see pre-bent lines are available. I think getting access to put them in ...would be extremely difficult. Has anyone ran flexible lines as a replacement? I am unfamiliar with lines and fittings, I would need some guidance on what to use and how to attach them, but I think this seems doable if I buy the correct stuff?
Opinions?
Old Mar 17, 2025 | 01:32 PM
ex-x-fire's Avatar
ex-x-fire
I'd replace it with nylon.
Old Mar 17, 2025 | 02:25 PM
Techun's Avatar
Techun
Like this?
Amazon Amazon
Old Mar 17, 2025 | 07:01 PM
ex-x-fire's Avatar
ex-x-fire
No like this. This is thin wall tubing.
Amazon.com: Dynamic FLK-38 Automotive Replacement Fuel Line Repair Kit 3/8 in (10mm), 23 Pack : Automotive Amazon.com: Dynamic FLK-38 Automotive Replacement Fuel Line Repair Kit 3/8 in (10mm), 23 Pack : Automotive
Old Mar 21, 2025 | 02:51 PM
Techun's Avatar
Techun
I marked the lines...but can someone confirm which line from the tank (top or bottom) is the send? Then I can make sure that line ends up going to the fuel filter.
Old Mar 21, 2025 | 05:16 PM
IHBD's Avatar
IHBD
Pro Mechanic
It's a little difficult to see in the pic which is which, but the two lines are different diameters. The supply / pressure is 3/8", and the return is 5/16".
In the second pic, where the lines have been cut, the "top" one appears to be the smaller diameter, so it is the return. The larger 3/8 is the supply, and goes to the filter.
Old Mar 21, 2025 | 05:38 PM
Techun's Avatar
Techun
Oh, I thought early cars had different sizes and later cars both moved to 3/8. If they're different that makes things easy
Edit - my 3/8" flexible line fits over both lines with equal difficulty. Can't tell a difference between them...wish I had calipers.
Old Mar 21, 2025 | 07:01 PM
ex-x-fire's Avatar
ex-x-fire
Use an open end wrench to measure the tubing.
Old Mar 21, 2025 | 07:35 PM
IHBD's Avatar
IHBD
Pro Mechanic
Originally Posted by Techun
Oh, I thought ........ later cars both moved to 3/8.
I used the wrench method and checked my 92 just now. It's parked on my 4-post lift, but on the ground. I just checked the lines under the passenger door. I'm pretty sure you're right, they are both 3/8".
I wonder if the 3/8 return has something to do with reducing restriction when the ZR-1's dual fuel pumps are on, and it was easier (cheaper) to install the larger lines on all cars regardless of which engine is under the hood?
I learned something too. Thanks.
Old Mar 23, 2025 | 11:35 AM
Techun's Avatar
Techun
99.9% sure both my lines are 3/8"
Some of the rubber isolators seem to have different sizes for each line. But yeah a 3/8 wrench fits over both and a 5/16 wrench will not.
Old Mar 23, 2025 | 02:18 PM
Techun's Avatar
Techun
Oh, and I tracked/guessed correctly since it runs after I patched it all.
To Replace leaking fuel lines
