C4 Intermittent Misfire
Old Mar 17, 2025 | 10:38 AM
Jeepster1949's Avatar
Jeepster1949
6th Gear
Default C4 Intermittent Misfire
I first posted this several months ago and received a rude response from some member who claimed it was was a "fish".
Trying again: I have. 1985 C4. Occasionally after starting it idles very rough. When driving it seems to "load up" and misfire. I take to my mechanic, it starts and runs well. He keeps a few days, starts it multiple times - no problem😩 I take it home and try starting it again. Same misfire problem. Any thoughts as to were to begin?
Old Mar 17, 2025 | 12:39 PM
s carter's Avatar
s carter
A little back History.
Last Tune up Plugs,cap,rotor- (a sticky gummed up plug will make a weak late cylinder) or a cracked cap or carboned rotor can make a weak spark. From cracked cap dampness in cap or carbon trail jumping spark.
Next have you put a pressure gauge on the fuel test port and see what your operating pressure is and if it bleeds down instantly, a leaky injector can make a wet cylinder that Fowls the plug (much like a lawnmower or dirt bike if it doesn't pop on first pulls)
How many miles on the car and does it puff smoke on first start after 24 hours (again see dirty weak plug)
Old Mar 24, 2025 | 08:01 AM
Jeepster1949
6th Gear
Thank you. 72000 original miles. Will check your suggestions.
Old Mar 25, 2025 | 01:14 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
I'd find a new "mechanic" preferably a diagnostic shop...general repair shops and dealerships only replace parts...good for them...bad for you !!
Old Mar 27, 2025 | 12:48 PM
MrRenoman's Avatar
MrRenoman
I'm sure there are different reasons for this but I would check the EGR valve for sticking. A lsticking egr valve may cause a miss. Just a guess.
To C4 Intermittent Misfire
