1996 corvette lt1
Old Mar 20, 2025 | 06:31 AM
aburks's Avatar
aburks
Default 1996 corvette lt1
I replaced the fuel injectors, fuel pressure regulator, fuel filter, and a used fuel pump out of a 93’ corvette I’m at 30-32 psi of fuel pressure. I pinched off the return line right before it meets the fuel pump n the fuel pressure went up to around 45-50 psi of fuel pressure, I believe it’s the check valve but to fix it do I just get a new pump or a new pump and sending unit?
