removing gasket residue
Old Feb 11, 2003 | 04:38 PM
LT4POWR's Avatar
LT4POWR
Default removing gasket residue
What do you guys recommend for removing gasket residue from the engine block, intake, heads, etc. I don't have any air tools, and I'm thinking there must be a better way than using a razor blade. Any suggestions???
Old Feb 11, 2003 | 05:03 PM
chucks88's Avatar
chucks88
Default Re: removing gasket residue (LT4POWR)
Razor blades and brake cleaner are my tools of choice
Old Feb 11, 2003 | 11:39 PM
zyal8r's Avatar
zyal8r
Well... sorry to say, when I did my water pump, I used a razor blade, too. Seemed to get the job done - tedious, but it did work. Actually did have to use a flat screwdriver in a couple of places where it was hard to manuever the razor blade.
Mike
Old Feb 11, 2003 | 11:53 PM
VMAX451's Avatar
VMAX451
I just use a razor blade, usually works great (you can nick aluminum if you're not careful though). Wipe with brake cleaner (or cleaner of choice) when done.
For really tough cases, you can also buy some gasket remover, it comes in aerosol cans. Spray on, let it soak in, scrape off. Make sure you read the instructions fully though to be sure you don't get it on anything it's not intended for.
Old Feb 12, 2003 | 05:30 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: removing gasket residue (Vince Ivanc)
Use gasket remover... 6 bucks or so at your local autoparts store, in the blue aerosol can... let it soak as long as you can bear to wait, then go at it with a razor blade. It should soften it up, and you can get some of the small crap with your fingernails. The gasket remover will burn your skin eventually, so make sure you keep some wd-40 or something around to keep your hands clean.
When I fixed my intake manifold leak, ~60% of the time was spent removing petrified old gaskets. :mad
[Modified by CentralCoaster, 2:32 AM 2/12/2003]
Old Feb 12, 2003 | 08:16 AM
96GS#007's Avatar
96GS#007
Razor blade. Make sure you change blades frequently. Gasket material really seems to dull them quickly.
:cheers:
Old Feb 12, 2003 | 02:17 PM
JasonL's Avatar
JasonL
Default Re: removing gasket residue (96GS#007)
Gasket remover helps. A warning though, it feels like snot, literally. So try to plug up the important holes in the engine before spraying :)
Old Feb 13, 2003 | 12:04 PM
OleDog's Avatar
OleDog
Default Re: removing gasket residue (JasonL)
Years ago when I worked in a shop we had a gasket tool. Hade a screwdriver handle long shaft and flat blade at the end that you could eventually sharpen on a grinder if needed. If I'm not mistaken you can get them in any auto parts store. Now that you got me thinking ,I think I'll buy one myself.
Old Feb 13, 2003 | 03:53 PM
LT4POWR's Avatar
LT4POWR
Default Re: removing gasket residue (OleDog)
Thanks guys
To removing gasket residue
