93 LT-1 Oil fill issues
Old Mar 26, 2025 | 05:12 PM
radar502's Avatar
radar502
Default 93 LT-1 Oil fill issues
93 LT-1 Org. oil pan , filter, I installed headers on this 93 the oil fill tube had to come out and it would not go back in so found another one on the forum no problem going back in now when changing oil with new filter, I pour in 5 Qt. showing it needs 1/2 qt to be full ,I have the Org ,dip stick it's in all the way in to the stop on the Tube and it bolted right were the Org one bolted in . I be thinking wrong tube. Any sugestions ..
Old Mar 26, 2025 | 07:50 PM
Whaleman's Avatar
Whaleman
I have found that with my bone stock 96 I also need 5 1/2 qt to be full to the top. I do allow mine to drain and drip for a long time so maybe that is a factor for a couple of ounces. Dan
Old Mar 26, 2025 | 09:25 PM
radar502's Avatar
radar502
Thanks ,was thinking before I changed the fill tube it showed right on the dip stick then after I changed the tube it was different, maybe not, anyway just corefuced the so call GM manual says 4.5 with filter, the dip stick says I need 1.5 Qt more so cool going with the dip stick. 5.5 Qts oil it is .. Thanks ..
Old Mar 26, 2025 | 09:30 PM
WVZR-1's Avatar
WVZR-1
Difficult to figure out what you're trying to say here BUT 1.5 qts I'd say is serious 'overfill' and asking for serious issues.
If the oil pan is OE you do a fill using factory fill suggestions and note the dip stick.
Old Mar 27, 2025 | 06:34 AM
Whaleman's Avatar
Whaleman
– Oil Type: The LT1 engine requires a high-quality, multi-viscosity engine oil with a viscosity rating of 5W-30. This ensures optimal lubrication in various operating conditions. – Oil Capacity: The engine oil capacity for the LT1 engine is approximately 5.5 quarts (including the oil filter).
This is a cut and paste from google. I know not the best source. Dan
Old Mar 27, 2025 | 09:33 AM
WVZR-1's Avatar
WVZR-1
From an appropriate FSM for LT1 VIN 'P' OB-8 or thereabouts any year. 4.0 Q less filter & 4.5 Q w/filter with a note *recheck levels after refill.
Old Mar 27, 2025 | 12:47 PM
Whaleman's Avatar
Whaleman
I know some people claim that halfway up the crosshatch area is "FULL". I take mine to the top of the crosshatch area. I sure hope that is OK. I have been doing it for years. Dan
Old Mar 28, 2025 | 12:58 PM
gtFOOTw's Avatar
gtFOOTw
I was curious about this too. Owners manual says 4.5 qt capacity with filter change, and that brings it to the halfway point between hash marks. But I always just put 5 qts in because that’s what I’ve done for every small block Chevy.
To 93 LT-1 Oil fill issues
