WTF is this noise?
Old Mar 26, 2025 | 10:21 PM
Kenlou's Avatar
Kenlou
Default WTF is this noise?
I have an 86 4+3 and have this strange noise coming from the right rear when I turn in either direction.
Old Mar 26, 2025 | 10:54 PM
gerardvg's Avatar
gerardvg
I tried to post a short video of the noise but it tells me the file exceeds the size limit. How do I get this to post?
​​​​​​The usual suspect of noise while turning is wheel bearing, a slight whine oscillating to growling
noise. Universal joints tend to squeak, when needle bearings in cap are dry and rusty.
Don't forget to check tyres for uneven wear? has the wheel alignment shifted, is not common for the camber bolt to move. Look at the rear tyres that there is no obvious camber difference side to side, uneven toothed tyre wear can cause howling growling noises like bad wheel bearings.
Hope it helps narrow it down
Old Mar 26, 2025 | 10:58 PM
Kenlou's Avatar
Kenlou
I’m going to try to get a video posted when I figure out how to do that
Old Mar 26, 2025 | 11:11 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Wheel bearing comes to mind
Old Mar 26, 2025 | 11:40 PM
Kenlou's Avatar
Kenlou
Here is that file
File Type: wav
Old Mar 26, 2025 | 11:50 PM
Kenlou's Avatar
Kenlou
Wow
Old Mar 27, 2025 | 11:48 AM
marshallnoise's Avatar
marshallnoise
Sounds like something rubbing more than anything to me. Didn't seem to change pitch much. Just a warble.
Old Mar 27, 2025 | 01:56 PM
AGENT 86's Avatar
AGENT 86
Here is that file
Jack up that side and check for wheel play.
Hopefully you will find the problem or narrow it down.
Old Mar 27, 2025 | 06:48 PM
IHBD's Avatar
IHBD
Pro Mechanic
If it only does it while turning and in both directions, it could be the posi clutches. If the noise is the posi clutches, they will only make the noise when there is a speed difference between the two rear wheels, like in a turn. They can't make noise running straight ahead.
. I had a similar noise in my 88 30 years ago when I used a parts store 80W/90 that claimed it had the posi additive in it already. It squealed like a pig when turning in either direction. The tighter the turn, the louder the squeal. I pumped that lube out and refilled with GM axle lube and 1 tube of the additive from over the counter at my dealer. Prior to then, and every posi axle since, all I'll use is the GM lube with GM additive. I tried "something else" once, and it caused noise. The GM stuff never has. YMMV.
Old Mar 27, 2025 | 09:04 PM
Kenlou's Avatar
Kenlou
It does do it only when turning in either direction. That audio file was made while driving in a circle. You wouldn’t have the name of the lube and additive I should use?
Old Mar 27, 2025 | 11:22 PM
JETS C3-C4's Avatar
JETS C3-C4
deleted duplicate
Old Mar 27, 2025 | 11:26 PM
JETS C3-C4's Avatar
JETS C3-C4
ACDelco GM Original Equipment 10-4003 Limited Slip Axle Lubricant Additive - 4 oz
I believe you use two bottles of the additive.
Gear oil 80W90.
Old Mar 28, 2025 | 02:29 AM
IHBD's Avatar
IHBD
Pro Mechanic
I'm curious. Did you change the axle lube, and now the posi makes noise? What lube did you use that isn't working out?
Here are the GM long numbers for the lube and additive. These get a zillion hits in a search for purchase.
89021671 Axle lube.
88900330 Positraction additive.
I begin with one bottle of additive, and it is usually enough. If after a period of time the posi is still binding or jerking in turns, add another 4 oz. You probably won't have to. Cheers.
Old Mar 28, 2025 | 02:39 AM
WVZR-1's Avatar
WVZR-1
89021671 Axle lube.
88900330 is same as ACD 10-4003 (posted earlier)
89021671 is same as ACD 10-4052
Mentioned ACD numbers to ease maybe comparison shopping. Single bottle is generally sufficient as mentioned.
Old Mar 28, 2025 | 02:41 PM
Kenlou's Avatar
Kenlou
I used the ROYAL PURPLE Max Gear Oil 75W90.
To WTF is this noise?
