I have a 93 vert which is a grocery getter located with me in Central Florida. When I supercharged the stock engine I hit about 430 rwhp. It was a fun car to drive. After losing the rings, I went the 383 stroker route and reached 598 rwhp. As added protection I added a D44 rear end. I foolishly did not consider THE GEARING IN THE 700r4 tranny. As such,I could never control the power in First Gear. Other than a Powerglide tranny were/are any options available to me?
I to live in the center FL area and I saw these guys at just about every large truck/car show and they say they can build some tough transmissions for whatever you have https://monstertransmission.com/
As far with a overdrive automatic there isn't a straight bolt in the 700r4 aka 4l60 is it. A 4l80e with its 2.48 1st gear could be beneficial but it's larger in size and requires a fabricated mount for the C beam, as every other transmission. D44 was available with a 3.07 ratio may help if you installed a 3.45 or 3.54. You will still be able to the tires off with a 3.07. You could try to soften the tune in first gear. The 700r4 used a second gear switch to enable tcc it could also be used enable a change in the tune.
