C4 tires
Old Mar 30, 2025 | 04:27 AM
Jim85z51's Avatar
Jim85z51
Default C4 tires
So 1985 Z51 with the 9.5" wide wheels. Trying to find 255 / 50 / 16 tires is proving about impossible unless track tires are what you're looking for-
question 1- any good tire advice?
question 2 - what wheel/ tire combo fits well, and looks right ? Need 38mm offset to fit correct, and I don't want the ZR1 "look" 5 spoke.
thank you for comments!
Old Mar 30, 2025 | 04:52 AM
Schieby's Avatar
Schieby
https://www.1001reifen.de/michelin-p...QaAlqvEALw_wcB
https://www.hood.de/i/2-x-255-50-16-...0aAmSSEALw_wcB
Old Mar 30, 2025 | 05:01 AM
Jim85z51's Avatar
Jim85z51
Thank you, the bf goodrich tires are no longer available in the U.S. in that size, and the Michelin's look like a great option, although @ $500 (U.S. funds) per tire, they're 1/3rd the value of the car! Anyone ever track day that tire?
My bf goodrich sport comp 2's have been great, but getting too old to trust!
Old Mar 30, 2025 | 05:51 AM
Schieby's Avatar
Schieby
If you wanna track day those tires, why don´t you get the Toyo Proxxes. Semi slicks, that are real cheap.
With the Michelin, you don´t need new rims. I don´t think you get it cheaper if you have to buy another set of rims. Just my 2 cents...
Old Mar 30, 2025 | 06:59 AM
84C4Tom's Avatar
84C4Tom
I have an 84 Z51 and have been running these 245/16 TOYO TIRES for about 9 months. No issues whatsoever and they ride and handle well. If you use the size comparison chart they are only .4 inches shorter. I seriously doubt you can tell the difference by sight.
Old Mar 30, 2025 | 07:30 AM
Jim85z51's Avatar
Jim85z51
Thank you, I think your 84 would be on 8.5 wide wheels,(?) the 85z51 came with 9.5 wheels and have seen the 245's on them, look a little "stretched", may have to go that route-
Old Mar 30, 2025 | 11:10 AM
84C4Tom's Avatar
84C4Tom
My rears are 9.5. They fit fine and are not bulged at all.
Old Mar 30, 2025 | 01:57 PM
Jim85z51's Avatar
Jim85z51
Definitely looks like an option- thank you!
Old Apr 1, 2025 | 11:48 AM
jdjenk's Avatar
jdjenk
245 tires fit fine. You'll probably get someone parachuting in here to tell you the manufacturers say not to do it so you shouldn't, but I and many others have put them on without any problems.
Old Apr 1, 2025 | 01:05 PM
walleyfisher's Avatar
walleyfisher
quick look at discount tires this is non $500 tire
https://www.discounttire.com/buy-tir...-r888r/p/40820
Old Apr 1, 2025 | 05:04 PM
Jim85z51's Avatar
Jim85z51
Default R888r
Thank you re the triple8 R's, unfortunately the amount of rain in the Seattle area keeps me from wanting to run those, but- as a track day tire, it might be what I end up doing, !
Old Apr 1, 2025 | 07:14 PM
AZSP33D's Avatar
AZSP33D
Mickey Thompson ET Street S/S Tires 255/50-16
Toyo Proxes R888R Tires 255/50-16
Toyo Proxes RA1 Tires 255/50-16
$188-300 per tire
Old Apr 1, 2025 | 07:17 PM
AZSP33D's Avatar
AZSP33D
APEX makes an 18x10 ET30 wheel for the front of the wide body c6 that fits the early C4 all around, I think it only comes in SM10 wheel maybe a few others, and it’s a new size for them. If’s a flow formed version that’s cheaper than some of the tires cost, comes on sale occasionally.
https://apexwheels.com/wheels/apex-sm10-18x10-et30-wheels-5x120-65mm-70-3mm
To C4 tires
