U-JOINT TIME ANY BRAND I SHOULD AVOID?
Old Feb 11, 2003 | 09:36 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default U-JOINT TIME ANY BRAND I SHOULD AVOID?
Did some investagating today. Discovered at least one sloppy joint in half shaft. Going to replace both joints on that side. My local jobber sells precision brand joints. Is this brand ok? THANKS FOR YOUR INPUT!! :cheers:
Old Feb 11, 2003 | 10:04 PM
gtsyellow's Avatar
gtsyellow
Default Re: U-JOINT TIME ANY BRAND I SHOULD AVOID? (dankai)
personally i'd
#1 buy spicers by brand
#2 buy naepco only if spicers were unavailable
#3 don't buy any others.
Old Feb 11, 2003 | 10:34 PM
tpi 421 vette's Avatar
tpi 421 vette
Default Re: U-JOINT TIME ANY BRAND I SHOULD AVOID? (gtsyellow)
I would recommend Spicer
Old Feb 11, 2003 | 10:45 PM
vader86's Avatar
vader86
Default Re: U-JOINT TIME ANY BRAND I SHOULD AVOID? (tpi 421 vette)
Dont use anything but Spicer.
Old Feb 11, 2003 | 11:17 PM
TA's Avatar
TA
I just installed all six Spicers last weekend :yesnod:
Old Feb 11, 2003 | 11:19 PM
Oly's Avatar
Oly
Go with Spicer.
[Modified by Oly, 8:20 PM 2/11/2003]
Old Feb 11, 2003 | 11:35 PM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Um, yeah.... avoid anything that doesn't say Spicer on it! :D
Old Feb 12, 2003 | 12:07 AM
AGENT 86's Avatar
AGENT 86
Default Re: U-JOINT TIME ANY BRAND I SHOULD AVOID? (Marcho Polo)
There's a ringin in me ears!! I think it's saying spicer. Thanks for your input guys. I'll have the jobber bring them in!! :party:
Old Feb 12, 2003 | 05:44 AM
Mikedril's Avatar
Mikedril
Default Re: U-JOINT TIME ANY BRAND I SHOULD AVOID? (TA)
Who's got the best price and service for spicer universal joints?
Old Feb 12, 2003 | 07:17 AM
gtsyellow's Avatar
gtsyellow
Default Re: U-JOINT TIME ANY BRAND I SHOULD AVOID? (Mikedril)
probably your local auto parts stores. call & find one that can order spicer, i've found they charge similar and you don't have to deal with shipping.
Old Feb 13, 2003 | 09:47 AM
TA's Avatar
TA
This is where I got mine. No one in my area could come close to matching their price.
http://www.tomsdifferentials.com/
Old Feb 13, 2003 | 01:19 PM
Robey5's Avatar
Robey5
Got mine at "the last detail"
Spicer is the brand GM used, there is a pretty good reason for it. I have the front 2 done, going to pull/replace the rear 4 soon...before spring. I think that I was looking at 80 for all six Ujoints. ?tld.com?
good luck!
Old Feb 13, 2003 | 07:25 PM
Mikedril's Avatar
Mikedril
Does anyone have part numbers. I have a complete dana 44 that I am getting ready to swap for the dana 36 in the car. Iwant to change all the U-Joints and bushings before I do the swap.
Old Feb 13, 2003 | 07:40 PM
gtsyellow's Avatar
gtsyellow
it's a standard 1 ton u joint. part 1350, the driveshaft uses a 1/2 ton 1310. they also make these in a coated version which might not be a bad idea to get. it keeps the metal from reacting and seizing in place. the non coated ones are a bit hard to remove after a couple years. i've done it though & it's not too bad, just get coated if possible.
Old Feb 13, 2003 | 09:06 PM
Mikedril's Avatar
Mikedril
Thank you for the part numbers!! :cool:
To U-JOINT TIME ANY BRAND I SHOULD AVOID?
