I am new to the forums and looking for some advice on my 1993 C4 Corvette. I am looking to swap out the headlights with ones named "TRUE MODS 5x7 7x6 Inch H6054 6054 LED Headlights Bright H4 Chrome Replacement Lamp". Something to just get me back on the road when it turns dark out, I know they are a little bit cheap.
I have already ordered these and tested them with my bench-top power supply and they run at 46Watts roughly, 12Volts, 3.6Amps high beams and low is 2.8-3Amps. Does this sound about right for a direct drop in? I do not want to stress any wiring or blow a fuse by drawing to many amps to the headlights.
Wanted to hear others opinion on this headlight swap.
Thank you and have a great day.
HWSTAR X-6LED headlights, just pop old ones out pop these in ,I have a set in my 93 love them no wiring no nothing no blown fuse, just for the first time in a C-4 I can see where I am going .. I gave around $80.00 set .30 min changed out done deal ..
Looks like the part number is X-6 2022 I looked up the site go down to you see 2022 ,fits jeep GM ECT $80.00 AMZ
Thank you for the response. Seems like there are no issues throwing in those types of lights/lamps then. I appreciate the information. Have a nice day.
NO issues mine have been installed for a year no problem, was one but it was easy fix, I think the bright light indictor stayed on, had to get a little gismo to fix no big deal and not all who had installed them had this problem, the lights are great ..
