How to not ruin new Optispark
Old Apr 20, 2025 | 11:12 PM
1993C4LT1's Avatar
1993C4LT1
Default How to not ruin new Optispark
Have take my lt4 apart due to a leak at the crank seal. Is there a way to not let coolant fall on my new petris opti?
Old Apr 20, 2025 | 11:52 PM
Furias15x's Avatar
Furias15x
There's no water running through the intake so you wont get a big flood. Just make sure you really get the coolant level below the water pump as best as you can.
Old Apr 21, 2025 | 12:36 AM
IHBD's Avatar
IHBD
Pro Mechanic
I had to do exactly this repair. I removed both knock sensors and drained the block into a mortar mixing tub from Home Depot. Because draining the block doesn't drain the cold-side radiator hose, I also drained the radiator at its drain ****. Not a drop on the 1 year old Petris because the block was completely drained, and the hose was drained too. I was able to reuse the drained coolant.
Old Apr 21, 2025 | 02:22 PM
dburgjohn's Avatar
dburgjohn
drain from knock sensors. No coolant in block = no coolant on Opti. Then a fresh fill of new coolant and you should be good come next winter.
Old Apr 21, 2025 | 02:53 PM
Whaleman's Avatar
Whaleman
Even easier than the knocks is to blow the coolant out of the block with a shop vac. Dan
Old Apr 21, 2025 | 07:13 PM
1993C4LT1's Avatar
1993C4LT1
Thanks guys
I just was very careful with the coolant. Put a million towels. When I removed the hoses, I had a small funnel ready to catch the coolant.
Now, question is, do I spend the money on a dewitts.
Old Apr 22, 2025 | 02:17 PM
Yonker's Avatar
Yonker
Even easier method which I used several times was to drain the coolant from the radiator. Remove the thermostat, and take a shop vac and place it into the thermostat opening and suck every bit of coolant out of the engine that you can get. You can then remove the pump without and coolant leaking, and clean up is just emptying the shop vac tank.
Old Apr 22, 2025 | 02:37 PM
Whaleman's Avatar
Whaleman
It is easier to blow it out the radiator drain than clean up a shop vac. Best to remove bottom radiator hose. Blowing will get more than sucking. Dan
To How to not ruin new Optispark
