Adjustable fuel pressure regulator
Old Feb 12, 2003 | 06:10 PM
guywade's Avatar
guywade
Default Adjustable fuel pressure regulator
will this hurt in anyways if installed on pretty much stock L98, i'm thinking not as in more pressure, but as in better metering, of gas, i guess also as in better than stock???? TIA :confused:
Old Feb 12, 2003 | 06:13 PM
chucks88's Avatar
chucks88
Default Re: Adjustable fuel pressure regulator (guywade)
If your looking for a performance increase you'll need to decrease the pressure
Lean is Mean
Old Feb 12, 2003 | 06:58 PM
hngacurv's Avatar
hngacurv
Default Re: Adjustable fuel pressure regulator (chucks88)
I installed a AFPR on my pretty much stock 86. I'm running 24lb injectors though. I don't think you would have any problems as long as you adjust it right.
Old Feb 12, 2003 | 07:06 PM
1MoorTym's Avatar
1MoorTym
Won't hurt, won't improve the way gas is metered, won't do anything better than stock than provide the obvious rise in fuel pressure.
You'd basically want a AFR if you need to gain more flow from stock injectors if you need it based on other mods you made, or to increase pressure to compensate for larger injectors you installed based on other mods you made.
Larger injectors require more pressure to maintain an efficient spray pattern. Stock injectors can be pushed somewhat to provide more fuel by increasing the pressure to keep the duty cycle lower but they have their limits.
It all comes down to what other mods you've made to require additional fuel. Some have reported an hp increase with just a raise in fp, but I can't confirm that.
Old Feb 12, 2003 | 07:10 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
It won't hurt but may not provide any gains over a stock unit on a stock L98.
Measure current fuel pressure (with vacuum line disconnected) and set the AFPR to that value initially.
To Adjustable fuel pressure regulator
