1987 coupe. Battery is 2yrs old. When I pull the courtesy light fuse I measure 20ma draw. When the courtesy lights are on I measure 3a current draw. When the lights are out I measure 30ma again.
Is 30ma current draw a good level?
I'm thinking one or more of the door switches are not closing when I shut a door. I have found the courtesy light on a couple of times an hour after getting out of the car. Opening and closing the drivers door in those cases would cause the lights to go out.
30 milliamps is actually quite good. This is a normal draw to keep the ECM powered so that it remembers certain variables it's learned and stored in volatile memory for interacting with the fuel map... plus things like a draw from the radio to power the clock, etc.
50 milliamps is actualyl quite normal too for modern cars with a CAN BUS system. Yours obviously doesn't have that, but 30ma is still normal.
A draw of 3-3.5 amps is pretty common for things like lights that are stuck on, so my guess is that's probably what's happening. You did all the right things though... and it sounds like you found the issue.
all of my project cars have a quick disconnect battery connector installed. One twist and it changes to a zero milliamp draw
Can I ask where you install the quick disconnect? Is it on the battery itself (on the terminal) or something that's bolted down somewhere? This 84 Corvette my daughter and I have as a project will never be at the Concours d'Elegance unless I've decided to make really bad financial choices (or it's in the parking lot with the other guests), so I was thinking of something more permanent... just curious where you put it?
50 milliamps is actually quite normal too for modern cars with a CAN BUS system. Yours obviously doesn't have that, but 30ma is still normal.
Just a quick example of what I'm talking about... this is a 2007 Solstice GXP we picked up last week, and I fixed a parasitic drain (it was the old OnStar system)... after everything settled down (before it went into sleep), this is the normal draw just from the CAN BUS with nothing running...
RGR, thanks... I have one of those on my 84 now... for some reason though it doesn't always work, sometimes just shutting the door causes it to make contact again. I'd love to know if there's a convenient place that people have mounted a heavy-gauge switch somewhere that you can access, without having to pop / lift the hood.
