Soft brakes
Old May 25, 2025 | 10:38 PM
Impala Balko's Avatar
Impala Balko
Default Soft brakes
I replaced the brake booster about a year ago and ever since then the brakes have been soft with alot of travel.... the brakes still bite hard and will brake well but the pedal feels soft and spongy... I just flushed the brake fluid and it helped a little but I still don't like how the pedal feels. It does not add confidence when your driving as I am used to a firmer brake pedal. Any suggestions what can be wrong?
Old May 25, 2025 | 10:49 PM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
What I found helpful and to result in an improvement was to work the ABS on a good gravel road.
Don't have to go fast. Just work it a few times. Though I worked em for probably ten minutes.
Then go home and bleed again.
I'd read that on here some time ago, so tried it and it did improve the brakes.
Guess the booster pushrod could always be in need of a minor adjustment, too. Dunno...
Old May 25, 2025 | 11:25 PM
Impala Balko
I could do the ABS engaging and bleeding thing... how do you adjust booster pushrod?
Old May 25, 2025 | 11:47 PM
Natty C's Avatar
Natty C
There's a tool that you need to get the right measurement between the MC and the booster pushrod.
But..I don't think that adjustment is relevant to ''spongy'' brakes. That adjustment is more for pedal distance before the brakes/MC engage.
And that adjustment, if I recall, has to be done before you do any other brake work...or...youhave to bleed the caliper first and then do the adjustment on that. I forget the right sequence. There's somebody around here who knows more than I do about it, gare awn teed.
Here's a good explanation, though, of that specific adjustment...
Honestly, if you flushed em, I'd just work the ABS on a good gravel road for a bit and then go home and bleed em again.
Best to leave the brake booster stuff alone, in hind sight, as it isn't really relevant to the spongy brakes anyway, so far as I know. I probably shouldn't even have mentioned it. Just ads needless confusion.
Old May 26, 2025 | 12:34 AM
Impala Balko
https://youtu.be/YDlz7-X3S2g
the brake booster pin adjuster makes sense though... I literally took the new booster out of the box and installed it on the car and ever since the pedal hasn't felt right... maybe I'll have to grab one of those tools and adjust the pin. I can try re-rebleeding it as well
Old May 26, 2025 | 03:05 AM
C4industries's Avatar
C4industries
Yes. I would adjust the brake booster pushrod. Adjust it about 1/2 turn at a time and retest until you have limited freeplay in the pedal. You'll get much better brake feel when it's adjusted properly. And remember that you must maintain a little bit of freeplay or the brakes will start to drag.
After you've removed the 2 bolts securing the master cylinder, it's helpful to have someone sit in the car and slowly push the brake pedal down part way until you can access the pushrod. Hold the knurled part with a small vise grip pliers to keep it from turning while you rotate the hex end with a wrench.
Old May 26, 2025 | 08:01 AM
pltmgr's Avatar
pltmgr
I would adjust the brake booster rod as recommended but it is my understanding that a soft and spongy brake pedal usually means air in the brake system.
Old May 26, 2025 | 08:51 AM
C4industries
I've made this adjustment on a few C4s and I've found that the long pedal travel actually makes the brakes "seem" spongy even if there's no air in the system.
Old May 26, 2025 | 09:08 AM
jmalez's Avatar
jmalez
the aftermarket boosters look like they have a much larger surface area than the plastic oem booster, maybe put a re-stricter in the vacuum hose to the booster,
Old May 26, 2025 | 09:16 AM
jmalez's Avatar
jmalez
second cant you just put the rear of the car on jack stands the start the car and put it in gear, when I do that my abs goes absolutely bats **** crazy, might save some chipped paint verses a gravel road
Old May 26, 2025 | 09:32 AM
jmalez's Avatar
jmalez
last thing is that if your pin in the brake booster was off by a small amount your brake lights would stay on all the time even with the car turned off ( found out the hard way )
Old May 26, 2025 | 04:03 PM
Impala Balko
when i bled out the old fluid I saw no indication of air bubbles.
Old May 26, 2025 | 04:04 PM
Impala Balko
what does a vacuum restrictor look like and where can I get one... maybe it is over boosted?
Old May 26, 2025 | 05:15 PM
C4industries
Start by adjusting the pushrod.
Here's another test for pushrod length:
With the engine off, jack up one of the front wheels. Then, have an assistant rotate that wheel by hand while you slowly push on the brake pedal. Have your assistant tell you when they start to feel resistance from the brake pads. That pedal movement is your freeplay.
Old May 26, 2025 | 09:22 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I replaced my booster last year and I too just threw it in and would dial it in better at another time.
Today was that time as I noticed my master started leaking down the front of booster.
I don’t have the fancy gauge, so this is what I did.
I loosened pushrod adjustment nut and wound it out until it caused a gap between master and booster.
I then wound it back in a bit and added a drop of latex paint on the end of pushrod.
Wound it out a little at a time and slid on master, until the paint would leave a small trace on master piston.
I googled the gap and Ai said 20 thousand was good.
My blob of paint was 25 thousand by eye, so I called it good.
Tomorrow I have to bleed all 4 wheels, so I can’t comment on outcome yet 😆
Old May 27, 2025 | 04:04 PM
Impala Balko
That is what i was going to ask next what does the manual say is the proper air gap, i dont have the repair manual for this car (I should probably pick one up one of these days).
Old May 28, 2025 | 08:11 AM
AGENT 86's Avatar
AGENT 86
I don’t see the gap info in manual, just them showing factory parts and using a factory gauge.
To Soft brakes
Old Jun 11, 2025 | 01:23 PM
Impala Balko
Update.... I adjusted the gap which really didn't seem off but the pedal still feels soft with too much travel... I don't know what else I can do as there does not appear to be any air in the system. What can I do to firm up the pedal and make it feel more responsive throughout the pedal stroke?
Old Jun 11, 2025 | 10:40 PM
pltmgr's Avatar
pltmgr
Rereading this thread I don't see any mention of when the rubber flexible brake lines were changed. Old lines could possibly be giving the brakes a spongy feel. Many feel if there're 10 years or older they should be changed regardless.
Old Jun 12, 2025 | 10:47 AM
Impala Balko
the rubber brake lines that go from the hard lines to all of the calipers have all been replaced with braided steel lines about 10 years ago.
