Last weekend I replaced the fuel pump and fuel filter in my 86 C4. Drove it for a few days without issues but now it will not start. Checking fuel pressure it is at 0 and I do not hear the fuel pump turning on. I replaced the fuel pump relay and that did not resolve it. The fuel pump fuse is good and been replaced to ensure but still no luck. Any ideas?
If you are not hearing the pump come on there is a reasonable chance that the pump itself is bad. Sometimes new parts do go bad and I bet that is what happened to you if you are getting 12 volt at the pump.
I completely agree. What you didn't mention was: Did you replace the pump with a QUALITY replacement pump, or did you go on the cheap and buy some RockAuto or Amazon el-cheapo Chinesium unit? Some parts are worth the extra money for a quality part, and this is one of those parts.
I hate to say this, but there have been many instances of Chinese knock-off fuel pumps sold through Ebay and Amazon. Usually it's Walbro clones.
First, do you have voltage going to the fuel pump? A test light can tell if it energizes on initial "key-on" and the again when the oil pressure switch engages during cranking/starting. Beware of using a multimeter, cause you can be fooled by voltage but inadequate amperage (like a bad ground).
Next, did you reuse the pulse dampener on the fuel pump or did you use a short connecting hose? I've seen cheap hoses split after being immersed in fuel for a while. And I've had some personal reservations about whether my pulse dampener was sealing adequately (so I ditched it).
Lastly, yeah I've seen new parts crap out. I had a bad Delco Remy alternator (new) that had a bad winding. It would drop voltage occasional once the RPM climbed about 4K.
Replaced the fuel pump again and now it is working.
