1990 Valve cover question
Looking at the valve cover, the bolts look like they had some o-rings or gaskets that need some love. I’ve found felpro options for 93 and newer - unsure if there is a better option or if these are necessary at all. Photo attached.
also looking to replace the PCV valve/gasket as there’s a small amount of oil leaking from this point. Any advice is appreciated. I’m new here to all of this. Photo attached.
Normally it's just a metal washer under the bolt head, but some people will also stick an o-ring or a rubber washer under there s as nt to mess up the paint.
The PCV grommet you can get from Zip. They have the right sized ones and they're nice and tight. I just replaced those on my '90, in fact.
Thoses ones on RockAuto or wherever else are all different inside and outside diameters for whatever reason.
