Fuel pressure question
please help me
Today I check my fuel pressure and is ok, but I note a diferent thing.
fuel pressure is 42
question,
do the system mantains the pressure at 42 or drops ?
because I opened the switch and the fuel pressure climbs to 42 but I turn off the engine and the fuel pressure drops completely.
Do this is nomal ?, I believe that not.
let me know your opinion
regards
Hope this helps.
Mine wasn't holding pressure and it turned out to be a groove worn in the seating surface (face)of the regulator. I polished it with 300 grit , cleaned it and put it back in. That did the trick. Autozone sells regulator diaphrams for $22.00 I believe.
I hope this helps.
John
John 89
I already pinch the out line and the pressure continue drops, then I disconnect the return line and plug it with a bolt and clamps and the pressure mantains, then I supose was the regulator
Mantains but after some mins drops a little each time (very little).
Then tomorrow I will bought the regulator and the plenum gaskets
I apprecciate if somebody give the chevrolet part numbers
I will take out the fuel injectors and clean it and test it each by each and I will replace the o rings.
thanks, please help me with the part numbers the guy of the spare parts (chevrolet) is very stupid in the computer and I don´t have the cd or factory manual.
