What Sparkplugs should I get?
Old Feb 13, 2003 | 09:49 PM
MrNuke's Avatar
MrNuke
Default What Sparkplugs should I get?
I am running a stock bottom-end '85 L98, and am adding a Vortech 6PSI supercharger and super ram setup..
What kid of plugs should I opt for?
Should I get hotter or cooler plugs? Would AC Delco or Rapidfires be good?
Gimme some insight people.. :cheers:
Old Feb 14, 2003 | 05:31 AM
95AquaC4's Avatar
95AquaC4
Default Re: What Sparkplugs should I get? (MrNuke)
I am swapping to NGK TR6's for my 150 shot. They got high praise here. They are a stage colder than stock.
Old Feb 14, 2003 | 11:07 AM
MrNuke's Avatar
MrNuke
Default Re: What Sparkplugs should I get? (95AquaC4)
When I order sparkplugs, do I just say "I want a stage colder than stock"..
Will the counter guy know what I'm talking about, or will he give me the USUAL blank 'Deer in headlights' stare.
:D
Old Feb 14, 2003 | 04:28 PM
Flame Red's Avatar
Flame Red
I have used AC Rapid Fires with great success w my ATI. Stock heat range.
Old Feb 14, 2003 | 07:18 PM
MrNuke's Avatar
MrNuke
Default Re: What Sparkplugs should I get? (Flame Red)
Sweet.. Thanx :cheers:
Old Feb 15, 2003 | 05:01 AM
black bart's Avatar
black bart
If you go to one step colder plug that would be ok but with 6lb. of boost it is not necessary. Just don't use the platinum plugs they will cause detonation.
You need the old style plugs with heavy ground strap. I use AC Rapid fire.
Be sure to never use any fuel other than the best you can buy with a blower detonation is what kills the engine. Also if you have a chip in the ECM remove it before installing the blower. Those advance the timming thats a no- no with forced induction.
:seeya
Old Feb 16, 2003 | 10:11 AM
MrNuke's Avatar
MrNuke
Default Re: What Sparkplugs should I get? (black bart)
I will do. Thanks for all the tips..
I will be putting my stock chip back in, and I always only use 93+ octane fuel.
Old Feb 18, 2003 | 08:46 PM
J Z06's Avatar
J Z06
Should be interesting to see what kind of trap speed it puts out. :thumbs:
Old Feb 19, 2003 | 09:41 AM
MrNuke's Avatar
MrNuke
Default Re: What Sparkplugs should I get? (JD 90 383)
If everything works well together, I should hit 114-116mph.
Old Feb 19, 2003 | 11:53 AM
1QWIKLT1's Avatar
1QWIKLT1
If the car is stock with 6lbs on a L98 116 would be way out there for that car. I was going to say 110 tops with that setup.
Old Mar 10, 2003 | 06:13 PM
MrNuke's Avatar
MrNuke
Default Re: What Sparkplugs should I get? (1QWIKLT1)
:D Quite Far from stock :D
Pulleys, Coil, Full LPE superram setup (intake/plenum), targa exhaust, roller rockers, Dana44 with 3.45's + the vortech of course.. And I just might put the 8psi pulley on and setupa water injection in the intake.. :D
Let's just say it BETTER hit quite more than 110mph... :jester
By the way I went to Autozone, and asked for AC Delco Rapidfire plugs and asked for a 'colder set'.. The guy tried to look up Cold start valve, GLOW PLUGS and then I told him not to strain his head I'll get a part #... :yawn:
[Modified by MrNuke, 6:13 PM 3/10/2003]
Old Mar 10, 2003 | 08:44 PM
J Z06's Avatar
J Z06
One thing I have always forced myself to do when tinkering with a new combination: ALWAYS expect LESS e.t. and mph during initial testing. That way you won't flip out when you're missing a mph or two(tuning, spin, conditions) Trust me, it's easier said...but better for your mind. Nothing is worse than let down.
I do wish you the best in it's 1/4 mile performance. :cheers:
Old Mar 18, 2003 | 04:19 PM
85Procharged383's Avatar
85Procharged383
Default I use....
Mine calls out stock for a R43 Champion... and I went 1 range colder to a R42 and they burn very very clean. Not fouled in normal driving... and burn clean under wide open throttle. They are like a buck each too... Would be a cheap trial anyway.... They work great for me.
Old Mar 18, 2003 | 06:27 PM
Mr. Magoo's Avatar
Mr. Magoo
From: Damn taxes! Pimpin' Ain't Easy in Massachusetts
2018 C4 of Year Finalist
St. Jude Donor '03-'04-'08-'09
I just got off the phone with Nitrous Express and they told me to run a NGK R5671A-8 plug and go with a 035-inch gap.
I'm not sure if this is what you would need for your set up, but it may help the nitrous crowd lurking about. :D
[Modified by Mr. Magoo, 6:29 PM 3/18/2003]
To What Sparkplugs should I get?
