What does this wire do
Old Jun 17, 2025 | 05:16 PM
m.jar's Avatar
m.jar
Navigator
Default What does this wire do
Recently had a coolant line blow, replaced the t bracket with a straight connector as shown (side note, why was it a t bracket in the first place? breather valve or something?), when it went this wire came loose. I looked for where it'd attach but couldn't see anything obvious, topped off the coolant and drove it for about 15 minutes and everything seemed fine, no engine lights. Thoughts? It's coming from one of the injectors
Old Jun 17, 2025 | 06:59 PM
s carter's Avatar
s carter
EGR Temp switch/sensor, just look at the foil wrapped pipe over the rt. Valve cover.
As for your spliced coolant hose it was common years ago to put a prestone coolant flush tee there, your clean straight splice is as close as you will get to factory without a replacement hose
Old Jun 19, 2025 | 01:28 AM
spaceweasel's Avatar
spaceweasel
I still have my Coolant flush tee, and use it. Do they still make those?
Old Jun 19, 2025 | 02:27 AM
JETS C3-C4's Avatar
JETS C3-C4
Yes coolant flush tee's are still made. Just google "coolant flush tee" and you will be surprised how many results come up.
To What does this wire do
