Cooling fan wiring problem
Old Jun 22, 2025 | 10:58 PM
90Vetteowner's Avatar
90Vetteowner
1st Gear
Default Cooling fan wiring problem
Hey im new to owning a C4 and was trying to instal a manual cooling fan switch. Ik your supposed to splice into the green and white but my car does not have that. Ive tried to check further back in the harness and got no luck. any help would be appreciated
Old Jun 23, 2025 | 04:22 PM
dburgjohn's Avatar
dburgjohn
The computer provides a ground for the relay that runs the fans. You can add a switch to provide that ground (I did on my 1992) to manually turn them on. On the 1992 it will set a code when you do this but it does not turn on the check engine light. I also added a wire to the 12v output side of the relay back to an LED (one for each fan) so I can see when they are on regardless of the turn on source.
