Help! At a dead end!
Old Jun 24, 2025 | 08:42 PM
6stiffy9's Avatar
6stiffy9
8th Gear
Default Help! At a dead end!
1992 LT1 with misfire and backfire, no power when given gas, after replacing ignition control module (AC Delco), ignition coil (MSD 8226), MSD Optispark, spark plugs, plug wires and cats removed because they were clogged. Fuel pressure is good across the board as well as spark. What could be the problem? Please help!
Its my first Corvette and I love it!
1992 C4 Corvette Convertible LT1 in Black Rose Metallic and Black interior.
Last edited by 6stiffy9; Jun 24, 2025 at 09:31 PM. Reason: Added pic and better explanation of problem
Old Jun 24, 2025 | 09:28 PM
CorvetteRules's Avatar
CorvetteRules
Are there any codes??
Old Jun 24, 2025 | 10:24 PM
Siveck's Avatar
Siveck
MSD has not been good to me in my experience. Especially when mixed with GM control modules. No optispark expedience but coils and control boxes that would burn up factory ignition control modules incessantly.
Old Jun 25, 2025 | 12:30 AM
Krusty84's Avatar
Krusty84
MAP sensor? Throttle Position sensor?
That is where I would be looking.
Does it idle well? Only a problem when trying to drive it?
Old Jun 25, 2025 | 07:32 AM
6stiffy9's Avatar
6stiffy9
8th Gear
It fires right up but idle is rough. Im not familiar with checking for codes but will attempt to with the help of YouTube.
Old Jun 25, 2025 | 08:49 AM
Vets-Vet's Avatar
Vets-Vet
When did it start having the problem, gradually, suddenly ?
Old Jun 25, 2025 | 08:57 AM
6stiffy9's Avatar
6stiffy9
8th Gear
It had a slight studder under heavy throttle when I first got it. Its much worse after all the work done.
Old Jun 25, 2025 | 11:02 AM
CorvetteRules
You have to short the 4 and 12 pin of the OBD and diagnostic codes on all the modules while show on dash display.
Old Jun 25, 2025 | 11:17 AM
6stiffy9's Avatar
6stiffy9
8th Gear
Thank you for the info. I found a video on YouTube of someone doing exactly that but he didn't say the location of it.
Old Jun 25, 2025 | 11:17 PM
Haggisbash's Avatar
Haggisbash
Look under the driver side dash for this.....IGNORE THE LETTERING IN THIS PIC.
FWIW I'm having a similar problem with my '93 C4 and it hasn't thrown up any fault codes. I cleaned the MAP sensor with some sensor cleaner and that improved the rough running a little. Mine starts and runs okay until it warms up and it seems to run okay on full throttle.
Old Jun 26, 2025 | 07:11 AM
6stiffy9's Avatar
6stiffy9
8th Gear
Thank you for the information!! Greatly appreciated!!
Old Jul 2, 2025 | 04:49 PM
Shefler's Avatar
Shefler
Could you possibly have 2 (or more) spark plug wires mixed up? Sounds a little like timing issues.
Beautiful car by the way.
Old Jul 2, 2025 | 08:21 PM
6stiffy9's Avatar
6stiffy9
8th Gear
Im 99.9% sure the wires are correct. Thanks for the compliment! Its such a beautiful lady that I just have to get her back to her former glory. Her name is Purple Haze lol.
Old Jul 10, 2025 | 01:58 PM
Dynoking's Avatar
Dynoking
Un-plug the Mass Air Sensor. It will run rich as a pig but if it starts and runs you may have found your problem. Please update us with you progress including the eventual successful repair so others will be helped.
Old Jul 10, 2025 | 02:36 PM
6stiffy9's Avatar
6stiffy9
8th Gear
I will do that. Unfortunately its been about a week since I was last able to work on it but will be trying multiple things this weekend, hopefully finding a solution for that beautiful lady.
Old Jul 10, 2025 | 03:17 PM
FrankieD's Avatar
FrankieD
Originally Posted by Dynoking
Un-plug the Mass Air Sensor. .
'92 vette does not have a Mass Air Flow ( Map only)
Old Jul 10, 2025 | 03:51 PM
6stiffy9's Avatar
6stiffy9
8th Gear
I have a new sensor, plan to replace it this weekend.
To Help! At a dead end!
