1993 corvette
Old Jun 28, 2025 | 01:57 PM
W4R's Avatar
W4R
8th Gear
Default 1993 corvette
I just bought a 1993 corvette I’m looking for a good replacement transmission that can withstand a beating
Old Jun 28, 2025 | 02:29 PM
Whaleman's Avatar
Whaleman
You might want to give a little more info. Like, is it an auto or manual? Dan
Old Jun 28, 2025 | 02:31 PM
W4R's Avatar
W4R
8th Gear
it’s an automatic 40th anniversary LT1
Old Jun 28, 2025 | 04:37 PM
Whaleman's Avatar
Whaleman
It is possible to rebuild your trans with updated and stronger parts. Dan
Old Jun 28, 2025 | 06:50 PM
W4R's Avatar
W4R
8th Gear
I’m not sure I’m open to trying it.i just know I’ve lost reverse and neutral already. Is there like a kit I could use?
Old Jun 28, 2025 | 07:12 PM
arbee's Avatar
arbee
Originally Posted by W4R
I’m not sure I’m open to trying it.i just know I’ve lost reverse and neutral already. Is there like a lot I could use?
How the fk do you lose neutral??? You saying it's stuck in a gear??
Old Jun 28, 2025 | 07:25 PM
W4R's Avatar
W4R
8th Gear
neutral is drive reverse is drive all but park is drive
Old Jun 28, 2025 | 07:54 PM
W4R's Avatar
W4R
8th Gear
neutral is drive reverse is drive all but park is still park
Old Jun 28, 2025 | 08:36 PM
W4R's Avatar
W4R
8th Gear
is there a kit I could use to rebuild it without buying a ton of parts separately?
Old Jun 29, 2025 | 06:32 AM
Whaleman's Avatar
Whaleman
If you are asking this question you are not qualified to rebuild this transmission. Either take it to a local shop or shop online. Dan edit: I am not qualified either.
Old Jun 30, 2025 | 12:12 AM
500hp's Avatar
500hp
I build 4L60E GMs for a tranny shop...
sounds like the FORWARD clutches or 3rd/4th clutches (or both) could be smoked and stuck together, forcing them to be "on" all the time.
If you drop the pan, and you see a black sticky icky mess... it is probably those clutches.
If you just have metal in the fluid and on the magnet, there is a chance it is a sprag/roller clutch issue.
Where are you located?
Old Jun 30, 2025 | 07:58 AM
arbee's Avatar
arbee
That is what I had thought too but the OP has given such limited information to describe the conditions more adequately that I did not pursue it any longer. The only thing in this scenario that I question is he said he also gets "drive" when he selects reverse. If the forward/3-4 clutches are welded, he should get a total bind when the reverse input clutch comes on. I am thinking he has destroyed a hard part somewhere in the train. A destroyed rear planet would cause this.
Old Jun 30, 2025 | 08:40 PM
W4R's Avatar
W4R
8th Gear
At first it started grinding a little but once it got up to speed it acted completely fine then parked it for an hour then reverse started acting like it was parked and wouldn’t go into neural.so I just figured I’d learn to rebuild the trans myself because I can’t afford a big bill for it.
Old Jun 30, 2025 | 11:51 PM
arbee's Avatar
arbee
Everyone has to learn somehow. Start by watching teardown videos on Youtube. There must be hundreds of teardown/rebuild videos of the 4L60(E). Get yourself an ATSG manual that outlines all the specs for a rebuild.
Old Jun 30, 2025 | 11:54 PM
W4R's Avatar
W4R
8th Gear
I have been watching the videos on the tear downs to me it seems pretty straightforward to me and I’ll get the manual for it
Old Jul 1, 2025 | 09:42 AM
Whaleman's Avatar
Whaleman
I agree, YouTube videos can make almost anything seem very straightforward and easy. Good Luck! Dan
To 1993 corvette
