Does no CATs = backfiring
Old Feb 14, 2003 | 09:21 PM
C4kid94's Avatar
C4kid94
Default Does no CATs = backfiring
I was thing about removing the CATs and putting mufflers on(which would
mean I would have straits with only mufflers), anyway my question is would
this cause back firing, My friend had a 95' Camaro and had no cats with only
one flowmater muffler and his car backfires when he lets off the gas.
Old Feb 14, 2003 | 09:26 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: Does no CATs = backfiring (C4kid94)
Well it's not a true backfire really. Any exhaust leaks will make the condition even worse. It will make more noise for sure if you remove the cat but it's harmless. If you don't like the noise than you really should leave the cat in place.
Old Feb 14, 2003 | 09:41 PM
silver & red CE's Avatar
silver & red CE
...no cats...his car backfires when he lets off the gas.
When I had my Vette's PCM reprogrammed this was fixed, I guess the stock PCM programming runs rich when you let off the gas to prevent detenation, the effect is the "backfire" sound.
Eric
Old Feb 14, 2003 | 10:31 PM
chucks88's Avatar
chucks88
Default Re: Does no CATs = backfiring (silver & red CE)
My findings are the less restrictive the exhaust, the less it backfires.
1st exhaust mod.....muffler eliminators
2nd exhaust mod.....catless front y-pipe & hi-flo cat
3rd exhaust mod.....long tube headers
I noticed less backfiring (if you will) after ea. of these mods.
Old Feb 14, 2003 | 10:35 PM
Wheelman's Avatar
Wheelman
i dont think its really backfiring per se, just a lack of backpressure making a poppin sound when you let off the accelerator. I had my mufflers off for the last 2 weeks and it was doing this like crazy. Now that they are back on it has stopped.
Old Feb 14, 2003 | 10:42 PM
gtsyellow's Avatar
gtsyellow
Eric
completely correct, it's more of a popping sound but it's very normal. even the C5-R does this if you've had a chance to watch it race in person.
Old Feb 15, 2003 | 10:07 AM
C4kid94's Avatar
C4kid94
OK, so if I take the CATs off and have my cars air/fuel programed(which I
can have done very easy) this will eliminate the loud poping
Old Feb 15, 2003 | 10:11 AM
C4kid94's Avatar
C4kid94
Default Re: Does no CATs = backfiring (Wheelman)
Right now I have elims, and an X-pipe inplace of the resenator(SP?) and it
has a nice burble when I let off the gas but no poping, I just cant stand the
poping my friends camaro makes.
Old Feb 15, 2003 | 12:28 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
Mine gurgles a bit when I back off but I kinda like it... :) ...I have long tubes then pipes only back to stock mufflers...good luck
To Does no CATs = backfiring
