EGR System when changing to headers
Old Jul 15, 2025 | 02:44 PM
Arbix's Avatar
Arbix
Default EGR System when changing to headers
I know this has been covered here a hundred times, but the discussions keep deviating from the key problem.
I want to change out the stock manifolds in my 1985 C4 with long tube headers. No aftermarket headers appear to have those connections to the EGR System runner pipes on the sides of the engine. If I have to lose those pipes off the manifold, I pretty much have to do an EGR delete, correct?
Thanks in advance,
Arbix
Old Jul 15, 2025 | 07:13 PM
Incorvettei's Avatar
Incorvettei
You will have to lose the AIR pump
Old Jul 15, 2025 | 10:33 PM
flannel_man's Avatar
flannel_man
Cruise-In VI Veteran
EGR is completely different, it's on the passenger side head. The manifold tubes are part of the smog pump system
Old Jul 16, 2025 | 07:12 AM
ex-x-fire's Avatar
ex-x-fire
On the iron headed small blocks (vortec not included) the egr gets exhaust from the crossover port in the intake manifold. You must be thinking of the A.I.R. tubes on the manifolds/headers.
To EGR System when changing to headers
