Tru or False
Old Feb 15, 2003 | 12:04 PM
JCascia's Avatar
JCascia
Default Tru or False
The throttle position sensor on an 86 throttle body is adjustable. And if so how do you do it? :confused: :banghead: :boxing
[Modified by JCascia, 9:08 AM 2/15/2003]
[Modified by JCascia, 9:20 AM 2/15/2003]
Old Feb 15, 2003 | 12:06 PM
bogus's Avatar
bogus
Default Re: Tru or False (JCascia)
:confused:
There isn't a smilie with shrugging shoulders...
Old Feb 15, 2003 | 02:27 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
My method is on my site.
Old Feb 15, 2003 | 04:32 PM
hngacurv's Avatar
hngacurv
Default Re: Tru or False (65Z01)
:iagree: 65Z01 has a step by step process for this. I printed it out last weekend. BTW, Thanks. As for the shrugging shoulders smilie I have seen this one posted before
[Modified by castivers, 5:11 PM 2/15/2003]
Old Feb 17, 2003 | 03:14 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
True,
1) Get a GOOD digital VOM
2) Using a pin to pierce the center wire? on the TPS, connect the VOM probe to the center wire.
3)Place VOM in VOLTAGE mode. ((((Be careful here))))
4) Loosen the TWO screws holding the TPS on the side ogf the T-Body.
5) Turn on the ignition (DO NOT START ENGINE)
6) I think you're looking for .56 volts. "Thereabouts".
If you've GOT + .56 volts you're FINISHED!!! Yea.
If NOT:
Grasp the "tail" of the TPS where the plug connects to it and move it either up or down to adjust to .56 volts on your VOM.
7) When you have it adjusted to your satisfaction, tighter the two screws you loosened earlier making sure the voltage doesn't change when you do.
Turn OFF the ignition.
Remove your wire piercer or pisser if you stuck your finger.
That's it. Easier'n snot.
To Tru or False
