SR base or upper?
Old Feb 15, 2003 | 05:35 PM
vetteguy216's Avatar
vetteguy216
Default SR base or upper?
I am looking to purchase a SR base and upper in a short while but dont have the cash to buy both so I wanted to know which would be best to buy first?
:chevy
Old Feb 15, 2003 | 05:38 PM
scorp508's Avatar
scorp508
Well, the plenum and runners are the bigger restriction, but also easier to get off. I think I would do the base first just so I didn't have to do the plenum/runner job twice.
Old Feb 15, 2003 | 05:40 PM
Corvette0096's Avatar
Corvette0096
Default Re: (scorp508)
:iagree:
Old Feb 15, 2003 | 05:49 PM
vetteguy216
Does the base also increase redline?
Old Feb 16, 2003 | 12:48 PM
want2drivemy85's Avatar
want2drivemy85
Default Re: (vetteguy216)
I would imagine so. the base has bigger ports/runners than the stock one.
Old Feb 16, 2003 | 12:51 PM
vader86's Avatar
vader86
Default Re: (want2drivemy85)
As far as HP, the upper.
If you want it to be easier when you install everything, get the base first.
It'll still add power and raise the power band.
Old Feb 16, 2003 | 01:52 PM
scorp508's Avatar
scorp508
No. Your safe operating redline is a factor not of horsepower, but of quality of parts. Redline can be increased by installing a more high quality valvetrain, connecting rods, and pistons. It isn't as easy as that though.
Old Feb 16, 2003 | 02:08 PM
vetteguy216
Let me think here if I buy the base then the upper I would have to un/Install the plenum/runners twice. And If buy the upper/runners then the base I would also have to un/install the upper/runners twice.
Old Feb 16, 2003 | 02:23 PM
scorp508's Avatar
scorp508
If you do the upper first you are removing the superram plenum/runners the second time. Much harder than the stock stuff.
Old Feb 16, 2003 | 03:15 PM
VetteRacer282's Avatar
VetteRacer282
Default Re: SR base or upper? (vetteguy216)
Doesnt sound as "cool" but why not buy one and let it sit on the shelf for a short while untill you get the other one, that way you can only dive in once.
I got a complete, fully ported superram sitting on the shelf in the garage waiting untill I get my car driving as it is, and get I get the heads that match.
Just my 2cents
Matt
Old Feb 17, 2003 | 02:56 AM
vetteguy216
I got to thinking I did decide to go with te base first but would hooker 2149's be a better choice?
:chevy :cheers:
Old Feb 17, 2003 | 04:39 AM
LD85's Avatar
LD85
Buy the base, port your runners yourself as much as you can, and swap your plenum for a ported plenum at TPIS for $100!
Old Feb 17, 2003 | 04:49 PM
vetteguy216
How much hp would the hookers give me compared to the SR base?
Old Feb 17, 2003 | 05:39 PM
h rocks's Avatar
h rocks
Ok, now think about your question for a moment. You are talking about opening THE restriction in an L98 motor by improving the intake system. This is a GOOD thing. Headers (esp. 1 3/4" Supercomps) on a stock intake L98 are next to worthless. It will reduce your bottom end somewhat and not be able to raise the rev range because you can't get enough air INTO the motor. I went through the Supercomp installation/blood letting only to find that I did gain ~250 RPMs up top, at the expense of a little bottom end. I had the Accell base and large tube runners at that time. Now SR with a stroker and big cam. BIG difference.
IMO, save your $$$ for the whole SR intake. If you can't swallow the whole thing, you will get some gain from the base and porting the stock plenum. As Scorp stated, you will not have to go through the SR install twice.
[Modified by h rocks, 5:42 PM 2/17/2003]
Old Feb 17, 2003 | 05:45 PM
vetteguy216
Default Re: (h rocks)
I just ordered the SR base. Dont have the cash for the whole bit right now.
:chevy :chevy
To SR base or upper?
