1320 Electronics OBD1 Bluetooth Cable PC Options
Old Aug 20, 2025 | 01:17 PM
GlennS87's Avatar
GlennS87
Default 1320 Electronics OBD1 Bluetooth Cable PC Options
I have a bluetooth cable from 1320 electronics and have successfully used the ALDL Scan app on Android. Is there a way to use a more robust PC laptop program with the 1320 OBD1 cable? TYIA
Old Aug 20, 2025 | 01:22 PM
carriljc's Avatar
carriljc
GlennS87
When I was playing with burning chips I used TunerPro RT. Check this from google AI.... .... it's been over a dozen years but here is the website: https://www.tunerpro.net/downloadApp.htm
Connecting a 1320 OBD1 cable to a laptop for diagnostic purposes requires both the physical cable and appropriate software.
Here's how to generally set up and use a 1320 OBD1 cable with a laptop program:
  • Cable Connection:
    • The 1320 OBD1 cable typically has three ends: a 12-pin ALDL connector for the vehicle's diagnostic port, a 12V lighter plug for power, and a DB-9 connector (or potentially a USB connection depending on the specific cable model) to connect to your laptop.
    • Ensure all three ends are securely connected.
    • Many 1320 OBD1 cables utilize an FTDI chipset for USB connectivity. You might need to install FTDI drivers on your laptop if they are not already installed.
  • Software Setup:
    • Install the appropriate diagnostic software on your laptop that supports the 1320 cable. Popular choices for GM OBD1 include:
      • ALDL Scan
      • TTS Datamaster
      • TunerPro RT
      • ALDLdroid (an Android application that also supports wired and wireless connections)
    • If using TunerPro RT, configure the software to communicate with the cable:
      • Navigate to "Tools" -> "Preferences" -> "Data Acq./Emulation".
      • Select "Configure Plug-In Component".
      • Choose the correct COM port number that corresponds to the USB-ALDL Cable.
Old Aug 20, 2025 | 07:41 PM
GlennS87's Avatar
GlennS87
The cable is bluetooth only but my PC laptop has bluetooth .Will TunerPro work with bluetooth only?
Old Aug 22, 2025 | 08:58 AM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
You can use a laptop as long as it has blue tooth, Yes tuner pro rt will work as long as you have a blue tooth connection, make sure you have the proper files to use with Tuner Pro RT.
Old Aug 23, 2025 | 12:22 PM
GlennS87's Avatar
GlennS87
Thanks!
To 1320 Electronics OBD1 Bluetooth Cable PC Options
