84 corvette cam
Old Aug 25, 2025 | 08:43 PM
Thatpurple84's Avatar
Thatpurple84
Default 84 corvette cam
I have an 84 corvette carb swapped and I’m still using the ECM but am wondering if I can change the Cam.
Old Aug 26, 2025 | 10:36 AM
flannel_man's Avatar
flannel_man
Cruise-In VI Veteran
You "can" change the cam. Just don't be surprised if you only pick up a 10 to 15hp gain. The whole TBI to Carb swap is not a power adder. The bottleneck is the stock intake, followed by the double walled exhaust from the manifold to the cat, then the manifolds themselves, then the heads then the throttle body butterflys. At least the whole stock bottom end is good, with forged pistons
Old Aug 26, 2025 | 12:00 PM
mike1111's Avatar
mike1111
with carb swap, what is the ECM doing? I really don't know. might have to change distributer also. then it would be old school build. header, better flowing heads, better cam. better HP.
Old Aug 26, 2025 | 12:05 PM
flannel_man
Knock sensor and EST timing adjustments, EGR, charcoal canister purge,
To 84 corvette cam
