More Performance for a stock 1985 C4
I am the original of a 1985 C4 with the Z51 handling package. Thanks to some of you on this forum who talked this newbie through on replacing a failed water pump. I will browsed this forum to get more performance out of the L98. So far,
1. I have done the throttle body bypass.
2. Installed a K&N air filter and I enlarged the air box to allow more air to the intake.
I noticed that I got better throttle response after doing items 1 & 2.
So, what is the next step for higher performance. I have read the discussion on the smog pump removal and I am not so sure that it help much relative to performance. Should I been taking a look at headers or should I continue to focus on getting more air for the intake?
Thanks and I look forward to your responses.
Headers were the next step I went on my 86, which is basically the same as 85. It woke up the car a good bit.
Intake can be as simple as portwork for now, but going further requires some more thought as to your hoped final outcome for the car.
Regarding TPIS, I checked their web site but they almost never have the headers for the 85 C4 in stock. I don't mind paying for quality for I have read that many on this forum liked their products.
American racing have a nice set of 1.75" diameter stainless long tubes. I don't plan on racing so perhaps 1 5/8" diameter tubes are the way to go. I basically want to cruise around town with better performance than stock. What do you suggest?
Headman, Hooker, and the rest are less expensive. I don't know anything about their quality assurance. Not that I have many choices but do you suggest using any of these brands when TPIS and American Racing do not have the headers that I need? I am not real handy so I will have to pay some shop to do the install.
The magazine test times from 1985 are all pretty slow (like 14.5 seconds) so my power estimate may be on the high side. Long tube headers would be the last thing that I would recommend.
If long tube headers is the last thing that you recommend, what is the first bolt on to add? Best regards.
flow testing an intake manifold and head together, they will flow a percentage of what the head flows. for example, a head that flows 200cfm, adding an intake they could flow 90%. that's 180cfm together. porting intake could increase flow to 92%, 184cfm. It also may not flow that good. not going to flow 100%. I've never tested TPI. just going off of other people's tests.
I've tested same heads that come on 85, with a manifold that flows 237cfm on its own. together they flow 92% of head flow. 196 x 92%= 180cfm.
Progression was first a better flowing intake/cam/headers as stated above, and then next step down the road was a Lingenfelter Super Ram upper with ported from 38mm to 40+mm runners, with the same big base (added power above 5K without any noticable loss down low)... next step after that was ported heads, next step was TPIS 1204 Mini Ram (short runner) which may have made more at 6K on the dyno, but lost a lot below. The first jump was the biggest by far if you look at overall power from 3K to 6K... even if 6K was not the strongest, but still quite usable (biggest improvement 5500 to 6200 was was the Super Ram though, and everyone said you can't go above 5,500 they were wrong) and the rods/springs were probably at the limit there.
The next step after that starting 2 years ago (we'll ignore this one here, but only from historical accuracy) was a biggest step with 4.125bore aftermarket block, 3.75 forged crank, more agressive custom billet cam... and going with AFR210 Comp heads meant new intake was required, for me a bigger Miniram was necessary to be able to bolt to the 210 heads (I think 1205 but not 100% in case there's a 1206, certainly not 1204 Miniram, and it needed a little work to line up). The larger displacement was key to properly utilize the short runner MiniRam. I did contemplate a custom welded intake but the 1205 sized MiniRam was the easier solution. Pipemax and Performance Trends software was pretty much right on the money with accuracy of the changes, if you want to model and design/optimize to your liking and have the tenacity to accurately input dimensions especially CSA's and other details.
