More Performance for a stock 1985 C4
The problem with flow bench numbers for a resonance-tuned intake like the TPI is that the bench uses constant flow. There is no resonance because there is no intake valve or piston. So you can measure all the improvements in flow that you want with large-tube runners and ported bases, but that intake is still going to kill power above a certain RPM. You can slightly increase that RPM by increase the runner cross-sectional area, but not a lot. You can also play some tricks with cam timing to mitigate the brick wall effect, but that also compromises power and/or efficiency at other parts of the RPM range. The Super Ram was a similar idea but with runners shortened to make it work at more modern RPMs, where power is made. As I recall, it's runners are roughly the same length as an LS1 intake's runners. That makes it a lot better option for those trying to build some power with larger-port heads and bigger cams. They are hard to find these days, but probably a great option for most who want to bump up power on an L98.
With your stock TPI, I do still believe long-tube headers will be a noticeable improvement. They tend to bump mid-range power due to primary tube length and collector volume (getting back to resonant tuning). The improved flow of the gradual bends and larger primaries probably matters little unless/until you change intakes, and maybe even heads and cam. But that just means they will "grow" with your future improvements. I'd say go for it, but be prepared that this is a big job and tying headers to the rest of the exhaust (or redesigning the exhaust) is not a cheap or easy project.
If you want to continue down the C4 path, take a look at Hooker Super Competition Headers. They aren't as expensive as the costliest headers, and they work well. Find a good shop that is willing to install them along with a full header-back exhaust (they will probably only be willing to do that if the new exhaust system includes cats). The labor is still not going to be cheap, but at least you'll save a bit on the headers.
https://www.summitracing.com/search/...cing%20headers
Make sure you specify "yes" or "no" to emissions bungs on the primaries, I said "no" to that so it's clean and I'm not running any air pump or egr... but they don't seem to have a different part number so make sure it's clarified somewhere in the ordering process.
