4+3 Transmissions...how durable?
But.... if you test drive the car you want to make sure that the 4 speed shifts nice and smoothly. Also you want to make sure the overdrive works. To do this you'll have to get the coolant up to a certain temperature as O/D will not engage unless coolant is at operating temp. It is different for every year.
Year.../Coolant Temp
1984 / 176* (F)
1985 / 140* (F)
1986 / 122* (F)
1987 / 122* (F)
1988 / 122* (F)
Once you have reached those temperatures you should be able to engage overdrive in 2nd, 3rd, or 4th gear. You'll notice an overdrive enabled light come on. In 1984/85 this light was in the center panel of the dash near the gas level gauge. In 86 through 88 it was moved to just over the digits inside the tachometer pane. It looks like a 'D' with a circle around it.
If you don't use the clutch during the overdrive gearchange (which I recommend you do to preserve its life more) you should be able to feel and hear the gear change.
In 1984/85 the switch is an ON/OFF switch. The overdrive program will never be on and O/D will never engage unless the switch is on. The switch is located on the center bezel in 84 and early 85. In late 85 the switch was moved to the shifter **** so that the button is actually the shifter pattern. Most people don't even know it is there.
In 1986-88 it is a momentary ON switch. In 86-88 the overdrive program is ON BY DEFAULT when you start the car so if you depress the button on the shifter **** you can turn it off.
It sounds a hell of a lot more intricate and difficult than it really is. It took me about a month to get used to the entire logic of the program and operation of it.
My 4+3 is the '87 unit with new internal peices that fix the problems 84 through 86 had. Right now my car makes 388hp and 439 ft/lb and the transmission doesn't even sneeze at it.
Good luck. Feel free to ask more. You may find this page very useful.
http://www.gearzone.net/dne.htm
Mine has been pretty easy to deal with, no major problems. It was rebuilt once before I owned the car. :cheers:
I've heard about the electronics being designed poorly so the switches go out prematurely.. but what else?
Mine's an '85, and appears to work like its supposed to so far.
BTW, the superT10 takes 4 pints, not 4 quarts, right?
