1984 c4 vette security light stays solid and wont start
long story short, the theft detterent module is likely fubar. in our case, it was melted, triggering the starter disable relay and also the horn.
the PO got around it by jumping/bypassing the starter disable relay by jamming the relay closed, and unplugging each horn. Because the horn was always on, the horn relay melted. Who knows how long it was like this.
I may have the “starter disable relay” backwards with a “starter enable relay”. they reversed somewhere i think in 85.
It is also possible that the theft deterrent alarm off/disable switches in the doors/kelock cylinder is not properly rotating and therefore the suggestion to unlock the doors with the key is not working.
I do think u could test this by unplugging the battery. That should reset the alarm. Then do not lock the car. not with the key nor the power lock switches. just dont lock it.
Does the horn still blare and it still wont start? If so, probably a toasted theft derre t system module, and maybe your horn relay is also fried.
the tdm is beside/above the ecm and was masking taped to the wiring harness. look it up. remove the pass seat, the pass kick panels, get on your back or twist/contort i think its 2x10mm hex head screws to drop the exm. Then find that tds module. replace it. might see burn marks.
your horn relay is behind the information cluster with the toggle switches and the idiot lights. need to remove the dash left to right. will need to tilt steering wheel down and then remove the tilt lever. can also remove the screw along the rearward underside edge of the dash pad and then gently flex it up and all the panels will come out nice. be patient. save tour phillips screws.
